Finding the "volume" of wood when reading a management plan
Started by Jase, January 27, 2025, 03:01:04 PM
Jase
I am here looking for confirmation or correction as I try to determine the volume of firewood that is up for thinning.
The next round of harvesting is detailed in my management plan as  the diameter class is in the 6-10" DBH range
Unacceptable Growing Stock: 10 square feet/acre in the 6-10" range. I assume we will let the AGS stay right where it is.
Stand size is roughly 100 acres. Assuming the trees are all 50' tall.
Somewhere I have come across an equation that suggests:
Volume= Basal area X hight / 3
Is that Correct, or am I lost in the pucker brush?
TreefarmerNN
Depending on the form factor of your trees, that formula may understate the actual volume.
There's a pretty good discussion here: http://ifmlab.for.unb.ca/People/Kershaw/Courses/For1001/Erdle_Version/TAE-BasalArea&Volume.pdf
There's a calculator in the toolbox section of this forum: https://forestryforum.com/calcs/Board foot calculator.htm
