Sawmill shed
Started by John_Haylow, October 24, 2008, 09:04:45 PM
John_Haylow
Hi everyone.
I finally got started on the sawmill shed that I have talking about for some time.The building is 24' x 36' using a cantilever truss giving me an extra 10' out one side with no posts to set the mill under. Most of the material was milled from pine from our lot.
I decided to put typar on as I will just be using random width pine boards for siding without using battens, I thought it would help keep the rain and snow out. I plan to use two 12' barn style doors on double tracks on each end so you can have a drive through effect.
I have good friend who is a builder and could not have done it without his help. I learned a lot and it was fun doing it.
Also is a picture of the outhouse before I had the roof on.
Thanks for looking,
John
2004 Wood-Mizer LT40HDG28
Robert Long
Hi John  8)
Very nice looking shed,  I wish I too could move along with such plans......but building permit problems and permits could become an issue down here.  Anyway, nice to see all is well with you! ;)
Robert
Captain
Nice sawmill shed and I like the portable bathroom as well.
Captain
gizmodust
Good looking shed.  And you always use privacy 8) 8)
Always liked wood with alot of character
Ron Wenrich
OK, I gotta ask.  Why all the room in the shed if you're going to be parking the mill in the overhang?  Is that for lumber storage?
It is a nice shed.
Bibbyman
Quote from: Ron Wenrich on October 25, 2008, 11:44:49 PM
It is a nice shed.
A lot of building for portable mills end up with a large overhang and the mill under it.  It gives clear access to three sides with no posts to bang into.  It would take a building maybe 4X larger to put the mill inside, get an opening big enough to get long logs into and have room to work around.
Sawing since '94
John_Haylow
It is a nice shed.
Hi Ron.
Bibbyman is correct about the overhang giving three sides unobstructed. The rest of the building will be used for equipment- implement storage. I also plan on having a 5th wheel trailer.
John
I like the over hang for the sawmill.Now you can saw in the rain and keep dry well sawing.Good planing and idea.
bandmiller2
Some of you guys that are limited to what you can build for a mill building,put up one of those plastic covered garages.When people get used to seeing it let it morf into a permanent building,start simple and let it grow.Frank C.
cheyenne
I hope you don't mind if I steal your overhang idea. I have been trying to plan a shed for six mos. with a 30' open side for my mill and you have solved my problem. Now i can build it the way I want. Good freind you have & many thanks....Cheyenne
Home of the white buffalo
Bibbyman
Here is a sawshed with overhang at the Wood-Mizer field office in Mt. Vernon, Mo.
Sawing since '94
John_Haylow
Quote from: cheyenne on October 26, 2008, 08:14:14 PM
Cheyenne, I'm glad you like it and hope it works out for you.
John
cheyenne
I think you might need a seat belt in that porta-potty...........Cheyenne
John_Haylow
Quote from: cheyenne on October 27, 2008, 09:09:52 PM
I knew I was missing something. ;)
John
Toolman
Also need an internet hookup in that pottie so that you can use forum while taking care of business. Efficiency is important :D          Darn nice saw shed!! That oughta keep ya out of trouble! ;)
"A government big enough to give you everything you want, is strong enough to take everything you have" (Thomas Jefferson)
bandmiller2
Usally your taxed on a building footprint not overhang its like free shed area.Whats really nice is a covered log brow to keep snow ice and rain off you and the logs.Frank C.
Handy Andy
  Here I was planning to start on my saw shed as soon as I get the rest of the beans cut and the cows moved home, and now  you guys are bringing up all sorts of ideas that make me scratch my head and wonder what the right way to build a saw shed is?  Was going to enclose the thing, and put a big door on the north with a smaller door on the south, so the air could blow through.  There is a tree on the west side, that I thought might shade the shed a bit in summer and keep it from being so hot.  Now I was readin about a way of getting the exhaust out of the building, and was also thinkin of a way to blow the sawdust outside.  So, maybe the right way to build it is with this overhang?  Was planning to do most of my sawing in winter, so thought the mill should be inside.  Then how to deal with exhaust.  My mill is gas, so that is probably nastier to breathe than diesel.  Sure as you put a turbo vent on, there won't be any wind when you want to saw.  And a huge pile of sawdust inside doesn't sound good.
My name's Jim, I like wood.
Toolman
YOU LUCKED OUT!! It's much easier to change your plans on paper!!!
Handy Andy
  No kiddin, staked it out today, decided the shed could be a little less in size without the mill in there, and lookin at 10' leanto for the mill.  Think I could use a bigger pole where those trusses go and just kindof mortise a hole through and put a board through and a bolt through it so I could get by without  a leg.  You see those type leantos on steel buildings without legs, bet I could do it with lumber.  Then I don't have to cantilever the trusses and make the building smaller.
