What is Ironwood?
Started by arojay, May 10, 2009, 02:33:11 PM
Rhodemont
On my Meadowbrook cart we refer to it as the singletree as the swivel bar that the driving harness traces hook to.  It pivots on the cart and takes the entire load.  I broke mine once and had to order a singletree.  I am pretty sure it is ash.  As for logging a bit with my horses we always call the bar directly behind the horse the whippletree.  When pulling with two or three horses the next spreader out are cross bars.  Using these names prevents miscommunication on hitching to a log which can be a disaster if done wrong.  I am sure this is all regional and depends on who taught you.
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
Old Scottish blood here called single yarding horse attachments swingle trees (single trees). I've not seen any horse logging book call it a whiffletree, although a single tree is considered a type of whiffletree. So 6 of one and half a dozen of the other. :D
Al_Smith
My experiance with horses is just Shetland ponies .Little knot heads .It's just a good thing they are small because they would be a chore to handle if they were as large as a draft  horse .
JD Guy
Quote from: Rhodemont on February 01, 2025, 12:56:02 PMThe  whippletree is the spreader bar that the horse work harness traces hook onto the ends.  In the center a hook for the logging chain to attach.
Thanks All!
