Rust?
Started by oregonsawer, December 05, 2010, 09:11:11 PM
oregonsawer
What do you guys use on the rail to keep it from rusting wile not in use?
I have used a lot of different types of oil and the next day their is rust!!!!!!!!!
Help please. And thank you in advance.
Oregonsawer >:(
5quarter
Oregonsawyer,
   I use paste wax pressed into a towel that I keep in a container near the mill. A quick wipe down each side... leaves just enough on the rails...no trouble with rust.
Chet
Blue Harbor Refinishing
Dewey
There is a procuct called Fuild Film  I use it on alot of my eguipment...  It is a great rust stopper also a good lubricant.. Google it... you can find it here in a farm supply store that is local... It comes either by the gallon or spray can
captain_crunch
You know the only way to Keep anything from rusting here in Oregon is to haul it to Arizona :D :D :D
northwoods1
I would 1st let it get a little rusty, in other words take the paint off good and prepare the surface of the steel with a light sandpaper or cloth, then let a very light surface build up of rust occur and keep wiping it off but don't kill the rust with any oil or anything. After this happens several times wipe the surface down real good with something like diesel fuel or light oil and kill the rust. By doing that you will greatly improve the surface of the steels rust resistance.
jimparamedic
Just like browning a gun. Or seasoning like ford use to do with engine block. Helps seal the pours of the metel
northwoods1
Quote from: jimparamedic on December 06, 2010, 09:52:24 AM
That is exactly what I am talking about the browning on a gun is exactly the same process. To brown a barrel I actually use a light acid to start the rusting process and control it to make it even but this isn't necessary. After the surface develops that patina it won't rust any longer or very little.
richard lane
WD-40 still works best in my book. Richard lane
