Author Topic: What size tubing to use ?  (Read 991 times)
Offline SCSawyer
  • If Your Not Sawing Your Wasting Time.
« on: December 12, 2011, 11:47:26 AM »
Hey guys need some input, Ive decided to put my little oscar on wheels, I need it to be as light as possible, so I have a little set of camper wheels and axles, and I need to know what size steel to build the frame out of, I was thinking 2x4 tube steel, do you think that will be sturdy enough at 18ft, should the axel be in the center or to the rear, I know it will pull better to the rear , I want it to be light so I can pull it to the woods behind an atv. Thanks in advance.
Silas S. Roberts , Bluff Mtn. Timber
Offline beenthere
Re: What size tubing to use ?
« Reply #1 on: December 12, 2011, 11:50:22 AM »
SC
Are you going to saw on that trailer too, or just move it around on the trailer?
Offline SCSawyer
« Reply #2 on: December 12, 2011, 11:54:43 AM »
Saw on it less the wheels, I was thinking of puting 6 of fold up screw jacks 1 on each corner and in the middle to level up with.
Offline beenthere
« Reply #3 on: December 12, 2011, 12:02:12 PM »
Then account for where the load points will be over the jack supports, and figure the weight of the saw plus the max log you might put on it.
Offline Bill Gaiche
  • Home built bandsaw, Kioti DK4510. Sthil 211&361
« Reply #4 on: December 12, 2011, 10:41:07 PM »
If you use 2"x4"x3/16" min. it will work. Place axle about 2/3's way from the front. You can spot the saw head anywhere you want to balance the weight the way you want and secure it there for moving. bg
Steel ramps for loading logs? What size tubing?
Started by Daburner87 on Sawmills and Milling
Last post October 05, 2021, 08:12:14 PM
by Patrick NC
2006 LT40 SHD Lubmizer clear tubing type? size?
Started by Blazer406 on Sawmills and Milling
Last post October 03, 2011, 01:53:29 PM
by Magicman
Need Info on LM 2000 > Clutch Shaft Size, Pulley Size, V-Belt Size for 23 HP BS
Started by H60 Hawk Pilot on Sawmills and Milling
Last post October 17, 2009, 07:57:09 PM
by Ironwood
New Tubing install
Started by metalman1 on Chainsaws
Last post April 04, 2019, 02:29:05 PM
by Old Greenhorn
