Author Topic: 35-40 Sharpening's  (Read 1576 times)
Offline highleadtimber16
  • Learning Everyday
35-40 Sharpening's
« on: August 10, 2013, 06:48:13 PM »
Went to a mill about 100 miles north of me the other day. I had a look around learned and saw some different things. The thing that really blew my mind was the number of sharpening's they get per blade! 35-40! They're running DoubleHard .42 thick 1 1/4" wide on 1" rollers. They use 3-4 blades per day on each mill. (Both LT 40'S, one gas one electric) They cut the same wood as me, big red cedar. Cuts are flat and straight as can be. Anyone else running this setup?
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline Sawmill Man
Re: 35-40 Sharpening's
« Reply #1 on: August 10, 2013, 07:42:03 PM »
Well they certainly cant be grinding very heavily or the set teeth would be touching that one inch roller. Anyway that beats my 6 to 7 resharpenings per blade.
"I could have sworn I went over that one with the metal detector".
Offline Bibbyman
    • Warden Sawmill
« Reply #2 on: August 10, 2013, 07:47:02 PM »
We run .045 x 1.25 DoubleHard blades and get more sharpenings than practical. But we saw mosty oak and hard, dry oak at that. The .042 blades should have longer flex life than .045 and far more than .055.
 I think the trick to long blade life is having the mill aligned properly, main drive belt tensioned correctly and push the saw speed to some practical limit.  And pull the blade before it is dull.
Their 40 sharpenings may have been one light pass each time. Let the blade get really dull and they may not last many over four.
Sawing since '94
Offline bandmiller2
« Reply #3 on: August 10, 2013, 08:23:53 PM »
How are they keeping track of the number of sharpenings,sounds like a bit of wishfull thinking.I get quite a few sharpenings but always seem to loose track, probably around 10 or 12 they don't break just get to a point where they don't cut straight. Frank C.
  • Learning Everyday
« Reply #4 on: August 10, 2013, 09:10:43 PM »
The guy that sharpens my blades or used to also sharpens blades for this mill. I went up so he could show me a few tricks. We had some spare time so we went to this other mill. He said he keeps track of how many blades he sharpens for them. By the time he reaches 35-40 the blades are pretty darn narrow.The mill pressure wash's their logs which probably helps a lot also. They also use B56 belts instead of B57. The sharpener worked for the Powell River sawmill for 30 years sharpening their blades so he knows what he's doing. He grinds the blades with an old woodmizer drag grinder.
EG 200 Wood-Mizer
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #5 on: August 11, 2013, 07:35:53 AM »
That's hard to believe 35 40 sharpening with the old drag one.
 I don't think you could do that with the new CBN one.
but I have been only sharpening Wood mizer blades for 25+ years.
Maybe there's a new way to do it  :D :D :D :D :D :D ;D
A&P saw Mill LLC.
License NH softwood grader.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #6 on: August 11, 2013, 08:16:10 AM »
To me, the 35-40 average sharpenings seems a little far-fetched.
Seems to me that just the flexing of the band (even a .042) would crack and/or break the band way before 35-40 sharpenings!
I keep track of the sharpenings of my .045's, and average 7-8 sharpenings each.
It's easy to keep track of my sharpenings because I use a vibrating etcher and mark each blade, each time it goes on the sharpener.
I use 4 diagonal lines and 1 horizontal //// to indicate 5 sharpenings, etc.
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline slider
  • sawyer,trucker,tree service
« Reply #7 on: August 11, 2013, 08:35:17 AM »
Sounds like a bit of a stretch to me but if he is getting that many sharpnings then good for him.I'm sure with that many years experience he has it down.Why don't you encourage him to join the forum.I'm sure he would be more than welcome here.
al glenn
Offline ladylake
« Reply #8 on: August 11, 2013, 08:50:33 AM »
 I've got quite a few sharpened from 1-1/4 down to 1" , taking off 10 to 12 thousands per sharpening that would be 20 sharpening's..   Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
  • Learning Everyday
« Reply #9 on: August 11, 2013, 12:26:34 PM »
I don't know. That's what he told me so that's all I can say.
EG 200 Wood-Mizer
Offline hamish
« Reply #10 on: August 11, 2013, 05:22:40 PM »
35-40 doesn't seem to far fetched, its all dependant upon how the individual sharpens, and how the sawyer cuts.
A light grind is all that's needed, if you all sharpened your pocket knives like you do you bands, you'd have a hard time getting a year out of one.
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Offline Happycamper
« Reply #11 on: August 11, 2013, 07:44:05 PM »
highleadtimber,
  I quite agree with with using the 56 belts instead of the floppy 57's ( never got used to that idea). But did they tell you how they install and remove those belts on the driven wheel???
                                Jim
Wether you think you can or you can't you're right
  • Learning Everyday
« Reply #12 on: August 11, 2013, 10:40:17 PM »
Jim, They said it's a b#$ch to get the belts on but it's doable. They cut them off once they run out of life. I plan on grabbing a couple tomorrow and giving them a try!
EG 200 Wood-Mizer
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #13 on: August 11, 2013, 10:49:24 PM »
As long as my sawmill manufacturer recommends B57 belts, that is what I will use.  After all, they spent the $$$ on R&D.
Offline slider
« Reply #14 on: August 12, 2013, 07:33:47 AM »
WD 40 helps
al glenn
Chain sharpening kit or automatic sharpening
Started by NovaSS on Chainsaws
Last post November 22, 2013, 02:29:18 PM
by thecfarm
Slick sharpening jig, for sharpening slicks.
Started by Dave Shepard on Timber Framing/Log construction
Last post August 21, 2017, 11:15:58 PM
by Andries
question
Sharpening Service vs Sharpening myself?
Started by mviezner on Sawmills and Milling
Last post October 05, 2019, 06:38:33 AM
by Peter Drouin
more sharpening ??
Started by Quartlow on Chainsaws
Last post October 22, 2004, 08:57:46 PM
by Kevin
