Author Topic: Useful sawmill mods  (Read 346104 times)
Offline lazyflee
  • \m/
Re: Useful sawmill mods
« Reply #1620 on: March 31, 2021, 11:16:17 AM »
Great ideas on this thread. Got sick of trying to get a wood block level and in the right place for the scissor jack. Welded up a bar and put some flanges on the jack. Slides to wherever I need it. Kubota blue(had no orange) but at least it matches the jack. Cordless impact driver works great.
Offline Satamax
  • Location: South eastern alps, in France but right on the italian border.
  • Living in Absurdistan!
« Reply #1621 on: April 02, 2021, 03:40:37 PM »
Guys, i found the swing arm for the winch, and the height control portal to be quite clever.
In french thought.
Offline Brob1969
  • New Sawyer
« Reply #1622 on: April 03, 2021, 09:34:42 AM »
Boy that French guy moves quick! :D
1990 Woodmizer LT40, 18 HP Briggs Twin II
1980 Ford 555 backhoe
1996 John Deere 4475 Skid-Steer
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #1623 on: April 20, 2021, 04:58:45 PM »
I recently added a horn/buzzer to my tractor so that I could get the attention of someone on the ground and this got me to thinking, what about the sawmill?  Often there are times when I need to get the attention of my tailgunner and my only option was to yell which was/is not very professional.  So what about a horn on the sawmill?
This $25 kit contained everything necessary to add the horn.
The horn is mounted below the control box.
And the horn button is mounted in the board dragback switch position.  I removed all of the board dragback before I completed my first year of sawing and I will not reinstall it so the position was available.
Can you hear me now??  ;D
Offline firefighter ontheside
  • I like trees.
« Reply #1624 on: April 20, 2021, 05:48:33 PM »
 @lazyflee where did you put that?  Starting end of the mill.  That could be a time save, especially when I'm working by myself trying to level a log.  I'm always using a lever to raise the log.  My arms aren't long enough to push down on a long lever and place a shim at the same time.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #1625 on: April 20, 2021, 07:27:55 PM »
I would put it on both ends of the mill. Use automotive scissor jacks they are all over the place in junk cars everytime we would cut a car apart during drills I would scavenge the scissor jacks out of them. They are very handy when you need to hold something in place and you only have 3 hands :)
Offline lazyflee
  • \m/
« Reply #1626 on: April 20, 2021, 08:07:41 PM »
 @firefighter ontheside I put it up front. Bought a cheap scissor jack from napa, think it was like $25. Used thick steel square tubing and get no flex. Use it a lot. First jack I had was a through pin handle, this one has a bolt type head so a socket fits right on it, first one I had to weld a head on.
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #1627 on: May 09, 2021, 06:17:15 PM »
A couple of mods that may come in handy.  Recently, I made  something that should enable us to saw a few inches wider.  I could have used this yesterday on the cedar.  It is 1" square tube that fits over the stop on the mill and on the bunks that will let you cheat the cant a couple of inches towards the drive side of the mill.
Also, There is another jig that allows for cutting cookies out of short logs or cutting short boards out of firewood sized logs.
Offline trimguy
« Reply #1628 on: May 09, 2021, 07:42:16 PM »
@caveman I like that. You need to be able to move it over to take full advantage of your cut width. I need to make me a couple of them. Thanks for the pictures.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #1629 on: May 09, 2021, 07:55:32 PM »
Most excellent!  I generally use a couple of 2X4's etc. but the cant is not secure.  I like that.....a lot.  smiley_thumbsup
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #1630 on: May 09, 2021, 08:44:21 PM »
Yes, thatís perfect very useful to get the most out of your sawmill.
Offline caveman
« Reply #1631 on: May 09, 2021, 08:52:29 PM »
I made these a few months ago but never checked to see if they would fit over the bunk stops.  They were close but did not sit down flat on the bunks.  They would have been handy yesterday when we were sawing big cedar but today I cut the holes a little bigger and now they fit.  Also, I should post in "Did something Dumb today".  I never put on shoes today as I was planning to kind of take it easy.  Well, I was using a grinder with a cutoff wheel to make the doodads that go on the bunks fit a little better and evidently discharged a 1"x 1/8" piece of molten steel on the floor.  I promptly stepped on it with my left foot.  It does smart a bit but I'll suck it up and walk it off.
Caveman
Offline 47sawdust
« Reply #1632 on: July 16, 2021, 12:59:38 PM »
My LT30 has a manual log clamp.At 74 that thing is starting to get heavy.Today I fabbed a stubby clamp that is 1/2 the weight of the factory clamp.
For $34.00 in parts and my welding,cutting and grinding time I think it will do the job,at least on most of what I saw.
Mick
Offline caveman
« Reply #1633 on: August 25, 2021, 01:24:34 PM »
This is not a high tech mod but it will hopefully save me from picking my tape measure or chalk up off the ground a few times during the course of the day.  I glued a couple of strong magnets to a box which rides on top of the controls.
Offline danxtro
« Reply #1634 on: September 09, 2021, 04:41:15 PM »
Nice! Magicman. I did the same on my sawmill. Very usefull. No more yelling to get attention.
Offline fluidpowerpro
  • Hi there!
« Reply #1635 on: September 09, 2021, 05:53:05 PM »
Depending on log and height of the head, the key switch on my mill isnt always easy to get to so for that reason last week I added E-Stop switches to each corner post of the frame. I have not needed to use them yet, but I know there will be instances where I will.
I also added an hour meter at the same time....
Change is hard....
Offline VT-Woodchuck
Toe board?
« Reply #1636 on: September 19, 2021, 05:52:01 PM »
Not an original idea, but works for me. Itís moveable, adjustable and is powered by a cordless drill. Makes leveling a log much easier than prying and trying to push the wedge under the log! Also, upgraded the clamps. Good move!
Offline danxtro
« Reply #1637 on: November 16, 2021, 04:02:27 PM »
I did a 2 in one i.e. a repair and a mod. Someone gave me an up/down electric motor for my LT-40. Told me that it was not working and was not possible to fix it. Contact studs were loose. I opened it and discovered that both parts of the brushes holder where the contact studs are normaly held in place are broken.
So I decided to create a part that will replace the missing portions of the brushes holder and make it with 3D printer
It is made of ABS plastic wich can sustain heat and is fairly sturdy. They fit perfectly with minimal filing on the outside edge. I had to adjust the lenght of the brushes holder area to fit properly with the printed parts.
The printed plastic parts hold the brushes holder in place firmly via the contact studs mounting nuts
I replaced the front bearing also and cleaned the collector
Motor works fine now.
Offline KirkD
« Reply #1638 on: November 16, 2021, 04:43:28 PM »
Nicely done! Are you going to be offering these to others? I know there are a lot of those older motors out there I know I have one.
Wood-mizer LT40HD-G24 Year 1989
Offline danxtro
« Reply #1639 on: November 19, 2021, 09:08:13 AM »
Thanks KirkD,
         I don't own a 3D printer, a friend printed the parts for me. I only modelised  it with Solidworks and saved the .stl file. Not sure if I would have the time for a production but maybe. I assume that this problem occured to many owners of those type of motor, since the brushes holder are brittle and can break easily if the contact studs nuts are overtighten.
sawmill mods
Started by doug olsen on Sawmills and Milling
Last post April 04, 2016, 04:25:41 PM
by WDH
My 12 sawmill mods
Started by arky217 on Sawmills and Milling
Last post July 25, 2020, 10:39:50 AM
by arky217
Woodland Sawmill Mods
Started by Billbob on Sawmills and Milling
Last post December 15, 2013, 04:21:35 PM
by Billbob
Home made sawmill mods.
Started by Clover on Sawmills and Milling
Last post March 22, 2017, 08:47:16 PM
by Clover
