Mill Swap
Started by highleadtimber16, March 07, 2021, 09:37:53 AM
highleadtimber16
Decided it was time to pull the old girl out of the shed and replace it with a shinier one.
Now I just have to figure out the setworks.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension,
EG 200 Wood-Mizer
Cutting Old Growth Cedar from Queen Charlotte Islands.
WV Sawmiller
   Why did you swap? What new features do you have now that you did not have before?
Southside
Wheel covers for starters.   :D.
White Oak Meadows
WV Sawmiller
  Oh, and maybe the air in the tires had gotten stale. ::) :D
barbender
😂😂 Sweet mill, and it looks like someone will be getting a nice used one, too!👍
moodnacreek
A circle mill would fit in there.
highleadtimber16
It's called updating equipment.
EG 200 Wood-Mizer
moodnacreek
Quote from: highleadtimber16 on March 07, 2021, 07:06:55 PM
I never thought of it that way.  Newer is always better and so is bigger.
Percy
That new one is  a 50. Vertical uprights and a chain turner. The cant wrecking claw turner I had on my old LT40 will never be missed...along with the pivoting uprights. You gonna love that mill.
terrifictimbersllc
...but she was just starting to turn pink... :embarassed:
tacks Y
Congrats on your new mill. New and old both diesel? What engine is on the 50? How many hours on your old one?
highleadtimber16
Both mills are diesel. 4650 hours on the old one and nothing wrong with it. I will be moving the LT40 across the yard and have someone else running it.
EG 200 Wood-Mizer
highleadtimber16
Quote from: WV Sawmiller on March 07, 2021, 11:33:30 AM
The air has been in there a while, but not as long as you've been around. So it should be just fine.
EG 200 Wood-Mizer
WV Sawmiller
   Thanks for the update. From the pictures I thought they were both LT50s and was wondering if it was just a cosmetic change or if you got some new functionality in the change. Since they are different I know you got a reversible chain turner instead of the claw. I don't know how much better the vertical side supports work but I do know I like the extra pair of side supports on mine when cutting short stuff. I don't know if anyone has developed extra side supports for LT50s and LT70s (Which I assume have the same side support system) or if they just use a scrap board on the side.
Southside
My 70 came with the extra side supports, they are manual.  I do use them now and then.
White Oak Meadows
highleadtimber16
I very rarely saw logs shorter than 8 feet, so the two vertical uprights are fine for me. My lt40 has all four linked together. They are great for the odd short or disfigured log. First full day on the new mill and I'm really enjoying the chain turner and vertical uprights. The faster hydraulics and up/down motor are great, but taking a bit to get used too.
EG 200 Wood-Mizer
