Author Topic: Working on 025 today, cold outside  (Read 411 times)
Offline welderskelter
« on: January 29, 2019, 05:43:16 PM »
Neighbor said it is 34 below right now and falling. Trying to get the 025 going today. Found I have a almost plugged fuel filter. It has a bigger end on it than the rest of my saws. I did take apart the filter and it has a white  cylinder in it.Thought I might shove it full of cotton and put it back together. Think it will work or should I do something else. Too cold to go anywhere today for parts. Harold
Offline lxskllr
  • dummy with saw
Re: Working on 025 today, cold outside
« Reply #1 on: January 29, 2019, 05:50:14 PM »
Unless you need a saw today, I'd wait and fix it right. I could see bits of cotton coming loose and plugging the carb. If you wanted to rig something, I'd probably look at a coffee filter. Wash it in gas to get any dust off first. Alternately, perhaps you could clean the existing media?
edit:
Maybe a cartridge from a different filter will fit, or could be modified to fit?
« Reply #2 on: January 29, 2019, 05:57:43 PM »
My neighbor said the old saws had a rubber bell like in the end in the tank and you just shoved in a cotton ball. I thought it might work.
Offline lxskllr
  • dummy with saw
« Reply #3 on: January 29, 2019, 06:03:26 PM »
It might. I wouldn't take anything I say as gospel as far as equipment maintenance goes. I'd be interested in hearing what others say. I'm conservative by nature, and my inclination is to not cheap out on already cheap parts unless you really have to. A cheap fuel filter fix could end up being a laborious carb cleaning. I just don't know.
« Reply #4 on: January 29, 2019, 06:07:27 PM »
Yeah I might wait. I just wanted to fix something today. Too cold to go out side. Ha
Working in cold weather – the human factor.
Started by Bibbyman on Health and Safety
Last post February 24, 2008, 01:47:06 PM
by SwampDonkey
Cold @ the mill today
Started by richhiway on Sawmills and Milling
Last post February 05, 2019, 08:25:01 PM
by starmac
sunny and cold @ the mill today. short vid
Last post February 10, 2019, 08:06:58 PM
by AZ_builder
Working from home today
Started by Crossroads on Sawmills and Milling
Last post April 28, 2021, 12:17:18 AM
by Crossroads
