Author Topic: Jonsered 2152 bar oil leak  (Read 1754 times)
Online SnoJetter
  • Gramps was a logger and he's got me doing it too!
« on: March 18, 2021, 09:53:06 PM »
I've got two 2152's and both leak bar oil. Yes, I know lots of saws leak a little bit. Some of mine I can store on their side to negate the leak; others I store bar "up." These 2152's I can store bar "down" to prevent the leak, but I'd like to fix the leak if possible. I also have opened the oil cap to relieve pressure and that didn't work. This isn't a major Exxon Valdez-type spill, but it's enough of a leak to leave a puddle about 2-3" diameter overnight when sitting upright. I tore one of the saws down to the oil pump and it appears it's coming from where the pump meets the rubber hose (see photo - note the pump screw has been removed, it's not actually missing). The oil looks to be pooling underneath that "seal" and then gravity brings it down to pool in the void underneath the pump part number.
The obvious answer is to replace the hose. But before I spend $15 on the replacement part, my question is if this is indeed the typical point of a leak on these saws or if perhaps there is a weak spot in the casting itself that is prone to leaking and requires a different fix (or perhaps no fix at all - just live with it)?
As a side note, I have a pair of 2150's which do not leak at all. Being plastic cases vs. metal, and having a bit of a different oil line arrangement, I wonder if the 2150 design just seals better. What does the collective wisdom think?
Offline Spike60
Re: Jonsered 2152 bar oil leak
« Reply #1 on: March 19, 2021, 06:55:38 AM »
Changing the oil lines will probably fix it. Those lines were improved with some additional "ribs" to help them seal to the case. Occasionally they can just get old and shrink a little bit.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Online SnoJetter
« Reply #2 on: March 19, 2021, 08:40:40 AM »
Thanks, Bob - that's what I am hoping for.
I had to replace an oil line on a lowly MS180 recently that wasn't oiling at all.  The rubber was old, had gotten a little hard and I suppose shrunk enough that it wasn't sealing to the pump and was just pulling air rather than oil.
I guess it happens to all brands...
Offline Tacotodd
  • To learn and help
« Reply #3 on: March 19, 2021, 08:46:51 AM »
Yes, to all brands. And listen to @Spike60 , because if itís a Husqvarna or Jonsered, heís going to be ďThe ManĒ!
After all, Itís what he does for a living.
Trying harder everyday.
Online SnoJetter
« Reply #4 on: March 30, 2021, 09:19:51 PM »
It took almost two weeks, but my oil lines finally showed up.  I was surprised as everything else I've ordered from the local Husky dealer in recent months has arrived in a matter of a few days.  At least they are here.  Unfortunately, I don't have a free evening to work on the saws until probably Friday.  Will update if this is indeed the fix.
Offline axeman2021
« Reply #5 on: March 30, 2021, 09:25:19 PM »
Hope we hear it worked good luck.
Offline mike_belben
  • Pulp Friction
« Reply #6 on: March 31, 2021, 01:09:51 AM »
The plastic case ones are prone to loosen the muffler and blow exhaust at the oil tank until it melts a hole in it. Youll see it behind the muffler.
Isaiah 63:10
Online SnoJetter
« Reply #7 on: March 31, 2021, 08:49:21 AM »
Before I acquired it, one of my 2150's actually ate a hole through the side of the muffler and that exhaust stream melted a large hole into the oil reservoir.  My repair was a large flange bolt head along with some JB weld.  So far it's holding just fine...but we'll see what the long term brings.
The two subject saws of this thread are 2152's (mag cases), so burning or melting aren't the problem in this case.
Offline John Mc
« Reply #8 on: April 03, 2021, 10:58:59 PM »
@Spike60 I've got a 2005 2152 that has leaked oil almost since the day I bought it. It seems to be coming from the same area as SnoJetter's. Can you share the part number I need to order to replace this line?
Is the installation very tough to figure out, or are things fairly obvious once I get in there?
Offline Spike60
« Reply #9 on: April 04, 2021, 10:09:51 AM »
John; can't get the part number from home, but will post it tomorrow from the store. Need to pull the clutch and oil pump, but a pretty straightforward installation.
Husqvarna-Jonsered
845-657-6395
Offline Spike60
« Reply #10 on: April 05, 2021, 11:55:19 AM »
Here ya go John;
537 101 102
Husqvarna-Jonsered
845-657-6395
Offline John Mc
« Reply #11 on: April 05, 2021, 01:52:18 PM »
Here ya go John;
537 101 102
Thanks, Spike!
Offline John Mc
« Reply #12 on: April 06, 2021, 08:20:42 AM »
@Spike60 - I'm picking up that part today from a local dealer.
Do you recommend putting some type of sealant on the barb/tube connection, or should it hold up OK with just the bare parts pressed together? If a sealant is used, what do you recommend?
Offline Spike60
« Reply #13 on: April 06, 2021, 09:25:12 AM »
I never use any type of sealant. But be sure to clean that whole in the crankcase good before installing. It is about the messiest part of the saw to work on and it seems like there always another chunk of crud that wants to jump in that hole.  :)
Husqvarna-Jonsered
845-657-6395
Online SnoJetter
« Reply #14 on: April 06, 2021, 03:51:10 PM »
I wasn't able to get to the shop until yesterday afternoon to install the new oil line on my first 2152.  @Spike60 is right, that is a very dirty part of the saw.  Add the extra oil free-flowing around there and it's a mess to clean up.!  I re-assembled the saw and let it sit overnight with a full oil reservoir and as of his morning, nothing pooled underneath.  I'll check again tonight, and of course will have to see what happens after I run it.  So far so good.
Interestingly enough, my second leaky 2152 is the saw I used most this weekend to salvage a bunch of firewood.  It sat in my wood trailer overnight...no oil leak (and the tank is not empty).
@John Mc if you haven't torn your saw apart yet, be assured it's a very straight-forward disassembly process.  The only minor snag might be spinning the clutch off the crank (LH threads, be aware).  I have the special clutch nut "socket" that makes the job a breeze with an impact wrench.  I'm sure there's a way around that if you don't have the tool.  Otherwise, a 4mm allen key and a philips screwdriver are all you need.
Offline John Mc
« Reply #15 on: April 06, 2021, 03:59:58 PM »
Thanks, SnoJetter. I've had the clutch off several times before. I tried one of the special clutch socket tools the last time, when I was replacing the drive sprocket. I probably should have stuck with the wrench, since using an impact wrench to loosen it just destroyed the tool (and yes, I did remember that it was left hand thread).
Offline Spike60
« Reply #16 on: April 07, 2021, 07:22:44 AM »
My official way to test these oil hose repairs is to only fill the tank 1/2 way. Let it sit overnight on a white piece of cardboard without a bar and chain and have a look the next day. Topping it off introduces the chance that the oil could expand and weep out of the tank vent. In fact we recommaned that saws not be stored with either the oil or fuel tanks topped off for that reason.
Ever notice that just about every saw that is stored in a case seems to leak oil?   Every drop of residual oil that makes it into the case stays there. A genuine leak like we are dealing with here will have everything swimming in that oil. The saw, tools, extra chains, rags, sometimes the owners manuel. And I don't clean the cases; "I'll fix the saw by the weekend and that will give you a few days to clean out this case for when you pick it up." :)
Husqvarna-Jonsered
845-657-6395
Offline John Mc
« Reply #17 on: April 08, 2021, 05:57:15 PM »
 @Spike60 - the local dealer had the oiler hose in stock - or at least what he says the part is. The pat number was written a bit differently: 537 10 11-02 (same numbers, just laid out differently.) It said oiler hose, and I had not yet looked at mine, so I brought it home and disassembled my saw.
It appears I have a problem: the two parts don't match.
Here is what I pulled from my saw
and here is what a comparison of the ends of the old and new part look like:
The new part is still in its sealed Husqvarna Group factory packaging, dated 2018/07/08.
Looking up the part number on the web site of a former forum sponsor shows a picture of that part number, and it looks the same as what I got from my dealer. Is it possible you got the wrong part number, or is there something else going on here?  If having a hard time searching for the part number to fit a 2152. I did find one website which shows a part number 503 854 701. However, the pictures do not show any ribs where the hose goes in to the case. I makes me wonder if they have the old-style part?
Offline Spike60
« Reply #18 on: April 09, 2021, 06:43:07 AM »
ooops, that's the early style you have. What would commonly be found on the 2149. Honestly didn't think that part change took place after the 49 was replaced by the 2152. I'll check the service bulletins and also get the other part number for you. The cases are different so the lines wont interchange as you see there. The newer set up uses a separate line from the pump to the bar plate.
Husqvarna-Jonsered
845-657-6395
Offline Spike60
« Reply #19 on: April 09, 2021, 09:22:38 AM »
 First 3-4 years of the 2152 did use that older line. Part number is 503 854 701. Still available @ $18. Sorry I steered you wrong on that one John.  :-[
Husqvarna-Jonsered
845-657-6395
Jonsered 2152 leaking bar oil
Started by John Mc on Chainsaws
Last post May 20, 2008, 07:10:20 AM
by ladylake
Jonsered 2141 & 2152 Hi RPM?
Last post November 27, 2008, 05:45:51 PM
by John Mc
Jonsered 2150 against a 2152
Started by smith2bj on Chainsaws
Last post December 21, 2009, 12:43:46 PM
by mad murdock
opinions wanted on Jonsered 2152 c
Started by Steven A. on Chainsaws
Last post September 27, 2006, 05:16:23 AM
by SawTroll
