Author Topic: 562XP short block drilled but not tapped  (Read 543 times)
Offline Sprinter
  • I'm not a sprinter but I used to drive one.
« on: June 30, 2021, 08:56:33 PM »
Lost another PTO side bearing so I'm changing out the short block & updating the air filter.
All was looking good 'til I got to the carb floor. 4 untapped holes. Got to looking and found 4 more.
2 at the the coil & 2 at the chain brake. Strangest part was the chain brake screws were started
but without threads.
As a side note: I found the impending bearing failure before the meltdown.
When rolling chain by hand I noticed the chain would do slack and then re-tighten.
Obviously uncaged ball (or balls) in the bearing.
Offline Tacotodd
  • To learn and help
Re: 562XP short block drilled but not tapped
« Reply #1 on: July 01, 2021, 09:56:56 AM »
OHHH @Spike60  , what do you think?
Trying harder everyday.
Offline Sprinter
« Reply #2 on: July 01, 2021, 10:34:05 AM »
My vendor tells me that they are all sent unthreaded as the screws are self tapping.
Could make sense if new screws were supplied. Only the two for the chain brake were.
Plus all the other holes were tapped.
Online Spike60
« Reply #3 on: July 01, 2021, 02:52:36 PM »
That's normal; how they've always come.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Offline Sprinter
« Reply #4 on: July 04, 2021, 09:38:59 PM »
Sorry if I threw out a bit of a red herring here but I was surprised to see that half of the holes untapped.
The good news is I did get them all in and the saw is back in action.
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
« Reply #5 on: July 14, 2021, 12:45:41 PM »
They are untapped, a soft material formed when the right screws are inserted and ran to tightness. Actually theoretically the best possible scenario.
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Offline Sprinter
« Reply #6 on: July 14, 2021, 06:24:56 PM »
So a little dab of Locktite should do the trick on the tapped threads as half were.
Husky 562XP short block update question
Started by Sprinter on Chainsaws
Last post May 02, 2021, 10:02:53 AM
by Sprinter
new short block
Started by Skioutty on Chainsaws
Last post May 08, 2019, 05:52:18 PM
by Mad Professor
What Happens when U wrap the remains of a 372XT around an AM short block?
Started by weimedog on Chainsaws
Last post July 24, 2018, 10:35:43 AM
by weimedog
High volume short block splitter
Started by r.man on Firewood and Wood Heating
Last post February 14, 2014, 08:20:30 AM
by Randy88
