Author Topic: Changing bar and chain 3/8lp.043 to 3/8lp.050  (Read 360 times)
Offline bundy
« on: August 08, 2021, 12:37:11 PM »
Can 3/8lp .043 bar and chain be changed to 3/8lp .050 on a Makita cordless. Both 16" 56DL. I have 2 bars and several chains from a Makita DCS 401 that I would like to use.
Offline lxskllr
  • dummy with saw
Re: Changing bar and chain 3/8lp.043 to 3/8lp.050
« Reply #1 on: August 08, 2021, 01:59:17 PM »
Should work, but might have a little less umph in the cut, and a small reduction in battery life.
Offline sawguy21
« Reply #2 on: August 08, 2021, 02:01:22 PM »
Welcome! Compare the bar tails where they mount to the saw, if they are the same then yes you can. The slot should be close to the same width and the oil hole needs to line up with the port on the saw.
Changing flail chain out today!
Started by thatchipperguy on Forestry and Logging
Last post January 29, 2016, 07:47:58 PM
by thatchipperguy
It is all changing
Started by Texas Ranger on Forestry and Logging
Last post July 27, 2017, 08:38:17 AM
by Wudman
? about changing passwords
Started by dun that on Technical Support Topics
Last post August 10, 2014, 03:05:56 PM
by Daver
Changing belts
Started by True North on Sawmills and Milling
Last post April 04, 2012, 08:59:04 PM
by True North
