Author Topic: Stihl 031 AV electronic spark trigger  (Read 397 times)
Offline 1stgenfarmboy
  • Member*
« on: August 13, 2021, 10:12:05 PM »
Does anyone know where I can get a new spark trigger for my 031 AV electronic ?
Thanks Dar
Offline Tacotodd
  • To learn and help
Re: Stihl 031 AV electronic spark trigger
« Reply #1 on: August 13, 2021, 10:20:31 PM »
What about the universal Oregon unit?
Trying harder everyday.
Offline thedoublejranch
  • 40+ acre timber farm
    • The Double J Ranch and Timber Farm
« Reply #2 on: August 24, 2021, 08:48:01 AM »
Thanks Dar
I had same issue, same saw even, the horseshoe unit under the flywheel failed, bought new updated unit from Stihl, this one was now outside of the flywheel in the air stream, probably for better cooling. I know its no longer made, as one suggested, the Oregon unit or the NOVAII unit should get you going.
The Double J Ranch & Timber Farm.
Member "NWOA" National Woodland Owners Association"
Offline Real1shepherd
« Reply #3 on: August 24, 2021, 10:10:08 AM »
Generally, it's been bad JuJu to place electronic parts under the flywheel-heat. Look at the problems SEM's has had doing that over the yrs.
There was an engineer though, that figured out how/where to remove the potting of the module and move the pulse capacitor remotely outside the flywheel...thus restoring a very famous Squeal model to service again.
Kevin
New 031 av electronic Stihl
Started by kmorgan on Chainsaws
Last post November 10, 2013, 03:45:22 AM
by H 2 H
stihl 020 avp electronic
Started by sandyman1216 on Chainsaws
Last post March 25, 2013, 10:48:56 PM
by bagman
need help with a Stihl 011 electronic ignition.
Started by meamjw on Chainsaws
Last post March 14, 2020, 10:03:38 AM
by Al_Smith
Stihl MS441 Electronic Carb.
Started by jteneyck on Chainsaws
Last post April 06, 2010, 03:08:06 PM
by JohnG28
