Author Topic: Chainsaw bar length  (Read 673 times)
Offline Guydreads
Chainsaw bar length
« on: August 27, 2021, 10:31:07 PM »
Hey guys! It's been awhile since I posted. I want to get a new bar, and I'm pretty sure as to what brand I want to get, I just want opinions on bar length. I run a Jonsered 2071 Turbo, so it could run up to (technically) a 36 incher. Not really interested in something that big. I'm going to be cutting smaller limbs some, not much as I have smaller saws that are easier on the back for that. Mostly 12-20 inch logs with an occasional 26-30 incher. I don't really know what size I should do, so any opinions would be appreciated.
Online btulloh
Re: Chainsaw bar length
« Reply #1 on: August 27, 2021, 10:54:47 PM »
24
Offline sawguy21
« Reply #2 on: August 27, 2021, 11:08:25 PM »
That would be a good choice, the saw is nicely balanced and has the power to handle it. Cut the larger logs from both sides when necessary. Yes, a 36" will fit but there is no point.
Offline doc henderson
« Reply #3 on: August 28, 2021, 12:25:51 AM »
20 to 24 sounds good.  I run a 25 on my 046 mag.  I have a 20 and 36 I rarely use on it.  I run a 20 on my 261.
Offline realzed
  • Old Fart
« Reply #4 on: August 28, 2021, 05:37:51 AM »
I too put a 20" bar on my 261..
Makes it easier on my back to reach down for grounded logs when cutting up firewood and as much as many say "20" is too big for that saw" it works quite well..
I like most, seldom ever bury the entire length of any bar completely in wood anyway - and even if I did the 261 has the power to pull a 20 easily from my past experiences with hard maple..
I personally consider any longer bar a bit safer when it comes to kickback as well, verses how quick a shorter bar could 'turn' on you..
Offline petefrom bearswamp
  • 70-13 still feel OK and am retired
« Reply #5 on: August 28, 2021, 08:32:47 AM »
Back when I was much younger and could bend over without any discomfort, I ran 16" and 18" bars
went to 20" about 20 yrs ago, much better on the back and handles everything I cut but I rarely cut anything over 20" diameter
Kubota 900 RTV
Polaris 570 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline Guydreads
« Reply #6 on: August 28, 2021, 10:43:34 AM »
Ok. Sounds like 24 is the answer. I'll post pics of the new bar at some point.
Online axeman2021
« Reply #7 on: August 28, 2021, 11:06:22 AM »
On my smaller Sthil 211 i run a 16 inch bar&chain on my larger Sthil 261 i run a 18 inch bar&chain.
Offline barbender
« Reply #8 on: August 28, 2021, 12:55:41 PM »
I run a 20" or 24" on my 2171, either one works quite nicely.
Offline Old saw fixer
  • Grumpy old man!
« Reply #9 on: August 29, 2021, 01:53:18 PM »
     For a long time I kept my bar lengths short, appropriate to the power and general use of each size saw.  For instance, a 16 b&c on the 261CM and my 036Pro was bought with a 16 b&c.  I'd like to put an 18 or 20 inch set on the 261CM, a 20 inch light set on the 036Pro.  I am coming to realize it's about reach, not as much as the size of the wood being cut.  I do more work cutting field edges back and thinning removing smaller stems from the wood lot than cutting logs.  I seldom need my 462CM 25", but it is handy with large blown down or just fallen down trees. I just "had" to have it!
     Small wood, small saw but don't bend down so far!
Stihl FG 2, Stihl 036 Pro, 017, HT 132, MS 261 C-M, MSA 140 C-B, MS 462 C-M, MS 201 T C-M
Logrite Cant Hook (with log stand), and Hookaroon
Changing chainsaw bar length
Started by Crookedkut on Chainsaws
Last post January 30, 2019, 01:07:33 AM
by Crookedkut
Max bar length for stihl 038 as chainsaw mill
Started by JoshNZ on Sawmills and Milling
Last post January 14, 2018, 07:03:42 PM
by richhiway
Cut-to-length system: feller buncher + chainsaw operators + forwarders
Started by cro-logger on Forestry and Logging
Last post November 22, 2010, 12:12:36 PM
by Ron Scott
Chain length, bar length, drive links, questions
Started by Jim_Rogers on Chainsaws
Last post May 21, 2013, 07:19:02 PM
by MEloggah
