Author Topic: wondering if this can be fixed  (Read 1085 times)
Offline chrisRBC
« on: March 19, 2014, 01:55:42 PM »
so yesterday I was cutting like normal with an old Stihl ms440 magnum when halfway through a cut I noticed that the bar was really loose. I pulled out of the log and the bar,chain, and cover plate just fell off. It looks like the rear post that holds the bar in place pulled out of the case and then the front nut wobbled loose. This event pretty much ruined my day. So, I was wondering what it would take to fix this issue, or if it is even worth fixing.
Proverbs 16:9
"For in his heart a man plans his course, but the Lord determines his steps".
Offline Ed
Offline GAB
Re: wondering if this can be fixed
« Reply #2 on: March 19, 2014, 02:21:37 PM »
chrisRBC:
If it was mine I would try to fix it using the right size helicoil.
Be aware that you might need to use a bottoming tap to get the helicoil down deep enough without causing further damage.
I would also change the other stud out while I was at it.
Gerald
Offline Al_Smith
« Reply #3 on: March 19, 2014, 02:59:01 PM »
With a helicoil or an insert it would take a larger hole .With the M10 056 stud you could just punch a spiral point tap through the stripped out hole .
Offline shelbycharger400
  • m14/04 0
« Reply #4 on: March 19, 2014, 03:08:57 PM »
I'd fix it,   but better put some stud retaining locktite on the helicoil
Offline JohnG28
« Reply #5 on: March 19, 2014, 03:44:23 PM »
At least try to fix it. And replace the other stud too, looks like the threads stripped on it.
Offline thecfarm
« Reply #6 on: March 19, 2014, 07:29:00 PM »
chrisRBC,welcome to the forum.
Offline chrisRBC
« Reply #7 on: March 20, 2014, 12:21:06 PM »
cool, thanks guys!
Proverbs 16:9
Down in the Dumps with my Kohler Engine / Not fixed / FIXED!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post April 09, 2016, 05:05:10 PM
by petefrom bearswamp
Just wondering....
Started by HiTech on Forestry and Logging
Last post March 24, 2016, 09:10:20 PM
by SWVAlogdog
I was wondering
Started by woodhaven on Sawmills and Milling
Last post July 11, 2003, 10:40:19 PM
by D._Frederick
Wondering what to bid on this ??
Started by Madman_Mark on Forestry and Logging
Last post August 09, 2010, 06:04:32 AM
by ljmathias
