Author Topic: question for a mechanic about a Walbro carb  (Read 969 times)
Offline ronbourd
  • Member*
« on: February 22, 2016, 07:46:27 PM »
Please can someone tell me what is the minimum pressure  (psi) that the needle valve should  hold before releasing on a Walbro carb , this is when you apply pressure with a tester on the fuel inlet hose.The chainsaw is a 154se Husqvarna.  Thank you for your help! Ronald
Offline joe_indi
  • The older I get the more I learn
Re: question for a mechanic about a Walbro carb
« Reply #1 on: February 22, 2016, 09:57:40 PM »
Minimum pressure not stated but maximum pressure is 14.5psi
Joe
Offline sharkey
« Reply #2 on: February 24, 2016, 03:16:54 PM »
Joe is correct.  Minimum reset is around 3.5psi, any lower and it will leak.  Try polishing the seat and see if you can get it up over 5.  Older seats that are brass tend to ovalize and once that happens theyre not coming back.
Offline ZeroJunk
« Reply #3 on: February 24, 2016, 04:03:13 PM »
Interesting, one of the top saw builders has a video about the problems with one particular HDA199 Walbro carb/saw combination and he wants it to hold 15 pounds minimum wet and doesn't care what it is as long as it is minimum 15 pounds.
Offline smmyb123
  • It's never the spark plug.
« Reply #4 on: February 24, 2016, 06:30:18 PM »
From what I understand, no modern carb should be pressurized above 10psi (.8 bar). It should hold 10psi indefinitely when applying pressure to the fuel inlet. Try pulling vacuum on the jet from the brass plug located under the metering diaphram, if any drop in vacuum then you have a bad check valve.
Need Help..........Walbro Carb!!!
Started by rahtreelimbs on Chainsaws
Last post August 23, 2005, 08:51:38 AM
by woodbowl
Walbro HD-17A carb replacement
Started by pwheel on Chainsaws
Last post September 01, 2015, 10:55:53 AM
by pwheel
question
echo cs 680 walbro hda 271 carb
Started by vladislav95 on Chainsaws
Last post May 20, 2015, 12:06:02 PM
by SlimJim
Walbro carb rebuild kits
Started by bundy on Chainsaws
Last post August 24, 2021, 03:30:34 PM
by Mad Professor
