Author Topic: Winter chain oil  (Read 3092 times)
Offline rank
Winter chain oil
« on: January 28, 2018, 04:35:08 PM »
The winter bar oil that my local chainsaw stores are selling isnít getting it done this winter.  Itís thicker than corn syrup.  Iíve tried ATF and that was a little better but I still want thinner.  What do the northern guys do?
Offline Andries
  • Making buildings out of big curvy logs
Re: Winter chain oil
« Reply #1 on: January 28, 2018, 05:05:14 PM »
Stihl bar oil, light weight.
MS660 and a 36" bar.
-42į C tonight.
Not a problem.
LT40G25
Ford 545D loader
Stihl chainsaws
Offline Gearbox
« Reply #2 on: January 28, 2018, 05:18:19 PM »
I run a multi grade year around . About 5 gal a year . Let you saw idle a bit then go at it .  It will thin as the saw warms up . In the summer I may add some heavy wt. if I think it is getting too thin .
Online thecfarm
« Reply #3 on: January 28, 2018, 06:39:37 PM »
I got it made now. I only cut on my land. I leave a jug in the OWB,most times I am back to the house and can refill than.
Offline rank
« Reply #4 on: January 28, 2018, 07:13:53 PM »
-42 holy crap.
Offline Andries
« Reply #5 on: January 28, 2018, 09:47:12 PM »
If it's windy tomorrow - I might take the day off. 😆
LT40G25
Ford 545D loader
Stihl chainsaws
Offline realzed
  • Old Fart
« Reply #6 on: January 28, 2018, 10:51:05 PM »
Is it a good idea to try and cut any Winter bar oil for use in really cold temperatures (it's supposed to be in the mid -30's here by the end of this week) with a lighter oil to drop the viscosity somewhat and get it to flow better while still retaining some of the tackability of the original oil for protection.. and if so what would be the best type of oil to use to use in anyone's estimation to do that?
Thanks - Randy
Offline JohnW
« Reply #7 on: January 28, 2018, 11:17:03 PM »
I agree with Gearbox, if you can get the oil in the tank the saw will warm it up.  I've never had any reason to cut wood when it's zero or less.
Offline Al_Smith
« Reply #8 on: January 29, 2018, 05:58:01 AM »
42 below ,oh my .Pity the poor brass monkey
Offline Al_Smith
« Reply #9 on: January 29, 2018, 06:05:28 AM »
Brass monkey aside in agony, in all seriousness I've used automatic transmission fluid .That was years ago for a small amount of cutting at around 15 below .It seldom gets that cold any more plus I really don't need to do it any more .
Offline moodnacreek
  • Sawin by the notches
« Reply #10 on: February 02, 2018, 07:32:04 PM »
Cut with kerosine
Offline thutch85
« Reply #11 on: February 02, 2018, 09:04:58 PM »
Stihl winter oil, comes in a blue jug. I've seen guys add a bit of diesel to thin it more. But as mentioned already, spinning the chain slow to build up some oil works too.
Offline rank
« Reply #12 on: February 03, 2018, 07:38:19 AM »
I guess the problem was my Stihl dealer doesnít carry it what I need. They have heavy and medium in orange jugs.  Iíll have to speak to them.  Thanks to all replies
Offline Stoneyacrefarm
  • Farmer/Service manager
« Reply #13 on: February 05, 2018, 10:14:54 AM »
I've been using the all purpose bar oil that they sell at tractor supply for years now.  It goes on sale for $6.00 a gallon periodically.
Works well on my husky saws.
Haven't had any problems with it.
Work hard. Be rewarded.
Offline mike_belben
  • Pulp Friction
« Reply #14 on: February 06, 2018, 09:24:06 AM »
Us poor rednecks use motor oil for everything.  Fence is dull?  Motor oil.  Trailer deck fading? Motor oil.  Got moles around your footing? Motor oil.  Stumps wont burn? Motor oil.  Theres a little tank on the saw thats not for gas?
Well by gawd i reckon it must be for Motor oil.
Isaiah 63:10
Offline teakwood
  • Switzerland
« Reply #15 on: February 06, 2018, 05:54:13 PM »
I changed the hyd oil on my 30to excavator, one barrel!
I won't buy chain oil for the next 3-4 years  :D
Super Tech bar and chain oil for winter
Started by North to Alaska on Chainsaws
Last post April 25, 2021, 08:50:53 PM
by thecfarm
Mill Chain, Heavy Duty Conveyor Chain' etc
Started by splitter on Wanted
Last post July 12, 2008, 11:34:36 AM
by TexasTimbers
Echo CS2711T - 1/4inch chain vs 3/8 inch chain
Started by Randy1949 on Chainsaws
Last post November 10, 2020, 05:03:40 PM
by Randy1949
Oregon Chain Grinder vs. Stihl chain angles
Started by Chelsea Tree on Chainsaws
Last post July 08, 2013, 07:58:36 AM
by bandmiller2
