New projects
Started by Kevin, January 16, 2004, 04:35:56 PM
Kevin
I have a couple of new projects coming up just as soon as the weather changes...
A Black Spruce along side the Trans Canada highway
A White Birch between two cottage buildings ...
That first one is an easy fix. Just tilt the camera a little to the right.
Kevin
I was hoping it might stand itself back up in the Spring.
Is that the one with the roots up in the air?
Kevin
That's it.
Maybe I could just paint it blue.  :D
I wonder if you could pull it back straight with a come along and then pin it down with some steel fence posts.
Kevin
It's a jungle out there.  :D
Here's a bigger picture --Photos MUST be in the Forestry Forum gallery!!!!!--.com/photo/26601181/111756663ywSASn
*hit the normal size button.
isawlogs
  It be alot easyer ifin that line wasn't there.
  You got it figured out yet hows you gonna take it down, all that calculating give you any ideas...
   Marcel
chet
Here's where ya get out yur throw bag to set yur rope or ropes. Those black spruce are purty tough and usually pull purty easy. But yur rope needs lots of height.
Sometimes when faced with a tree like that, that I don't know will HANG on I will use two ropes in it, each pulling at a 30 to 45 degree angle.
Or....... ya could always climb it and jump the top over the cable.  ;D
Kevin
There's a few  ways to tackle this one that I see.
Two as Chet described and a third where I partialy cut the butt and let the top rest gently on the strand then go up trim the top off close to the cable and come back down, finish the cut and let the tree drop to the ground.
Bro. Noble
Jeeze Kevin,
You're overlooking the obvious and easy way to do it.  I'd tell you but you always make fun of my brilliance ::)  Anyway it would take a helper.  Can you get anyone to work with you?
Kevin
Bro; helpers aren't in our budget.  :D
What's your suggestion?
They won't let me burn it down or blow it up.  :D
... and I'm not dropping the cable.
chet
Kevin, yur option wouldn't work for me. The folks I work for frown on the idea of resting trees on high voltage lines. Seems to always blow power.  :-/  They also aren't as tough as dem big fat Com cables.
Kevin
Here's a shot from my office yesterday --Photos MUST be in the Forestry Forum gallery!!!!!--.com/photo/26601181/111838517pkJIsw
Bro. Noble
Kevin,
Well never mind then,  I figgered I was wasting my time :-/
Wes
 Looks like a bucket truck job, or possibly a crane.
 Or if you get a good heavy snow it may come down by itself, then it will be an easy one.
Kevin
It's going to be a climb the rope and saw job.  :D
Minnesota_boy
Get a 1010 John Deere with loader bucket.  Raise it as high as it will go and push the tree back into the woods.
Stan
Have the phone company come out and lay the cable on the ground. No harm no foul, this don't work with electric lines.  :-/
I may have been born on a turnip truck, but I didn't just fall off.
chet
Minnesota_boy,   With a shallow rooted tree like a black spruce with that much weight leaning the way it is, there is a VERY good chance you would push the base of the tree out from under itself.
Kevin
Stan;
I am the phone company!  :D
I can drop the tree without dropping the line.
If I drop the line then drop the tree I have to raise the line again which involves more work than required.
I can safely remove this tree without the added expense of heavy equipment, it's about an hours drive one way up the highway.
etat
Would this be of any help! ;D ;D :) :)
Old Age and Treachery will outperform Youth and Inexperence. The thing is, getting older is starting to be painful.
Is that all he needs.....  a camera?   :D  Are we all going to wake up and find out this has been a dream? :D
Worse yet! Am I going to wake up and find out Y'all have been a dream? :D :D
Stephen_Wiley
Could it be......that cktate discovered when Kevin looked out his window, upon completion of a nap. That his head was still cocked in the slanted sleep position.  :D
" If I were two faced, do you think I would be wearing this one?"   Abe Lincoln
