Can anyone identify this saw blade?
Started by cawest, September 11, 2008, 07:56:56 PM
cawest
Can anyone identify this saw blade?  It's 56" diameter. Is it a crosscut or rip?
Chad
SCSawyer
not sure would have to see closer think its cross cut
Silas S. Roberts , Bluff Mtn. Timber
LeeB
I haven't got a clue but 56" seems awfully big for a crosscut.
cheyenne
I would say it be used either way. If it's thin probley rib, thick probley crosscut. Are those carbide teeth. Cheyenne
Home of the white buffalo
It appears to be an old headsaw before inserted teeth,with that hook it was used to rip.Whoever gummed it didn't know what they were up to those sharp corners breed cracks.The tips of the teeth were swaged for clearance.Frank C.
