Jig/Cradle For Short Logs
Started by gfadvm, October 23, 2013, 10:41:42 AM
gfadvm
Just joined this group and have a question: I recently purchased a Wood-Mizer LT15 and I'm trying to figure out how to mill logs that are24-30" long. I'm sure someone else here has solved this problem a long time ago and I'm hoping to learn from their experience. Thanks!
Yes, there are a variety of ways that have been posted on holding short logs.
Bridging that gap with a base board and having a 'fence" at the back to span the space so the clamp works are the basics.
A search may get those threads to come up, as well as several may see this and respond directly.
Do you get a lot of short logs to mill? And what is the product?
dboyt
Welcome to the forum!  I routinely cut short logs.  The clamps on the Norwood are movable to accommodate different log lengths, but for really short logs I bridge across two bunks with a board, then use a sacrifice board to bridge between stops, so that I cut the sacrifice board as I go.  The first cut is a little iffy, but once you get a flat side down on the board bridging across the cross bunks, it goes pretty well.  Here's a photo.
Norwood MX34 Pro portable sawmill, 8N Ford, Lewis Winch
Welcome to the Forestry Forum,  gfadvm.   :)
Deese
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Ga Mtn Man
Ga Mtn Man
Gasawyer
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
gfadvm
You guys are really helpful! those Links were the answer for me. I knew someone had been there, done that.
I really appreciate the help. I often get given short crotch cherry or walnut that people have cut for firewood and don't want to split it. I agree: burning cherry and walnut is a shame!
Thanks for the helpful responses. I'll probably be back with more questions.
gfadvm,what's the plan for lumber coming off the mill?
gfadvm
The short stuff will be for boxes and door panels for the most part.
The longer boards will become chairs, tables, or ?
I am a hobby woodworker that always wanted a mill and I found one on CL that seemed too good to pass up! Now I need to sell more chairs to pay for it!
As an FYI a buddy did a Sketch Up of a really cool short log jig on my Lumberjock's thread. Not sure if I'm allowed to post a link here.
delvis
gfadvm,  Welcome to the forum, these folks are great and always very helpful.
All I can tell you about short stuff like that is I hope it is for something you want or need and not for a customer.  It is very hard to make any money with stuff that short because there is just so much work involved compared to the actual board feet you get out of it.
I tell all my customers to please make sure the logs are at least 8 feet long because it makes everything go easier from the turning to the tapering to the clamping to the sawing to the off bearing etc.
Good luck with whatever method you decide to use.
If I never saw another board I will at least die happy having spent the last few years working with my dad!
Tom the Sawyer
This topic is somewhat dated but a new topic would have been so similar that it might be better to keep them together.   say_what
A while back I had to split about 40 peeled posts for a special project for a cabinet shop.  I had a devil of a time keeping them steady with the clamping system on my mill, so I came up with something else.  Then it was quite some time before I needed to use it again... until today.
This was reportedly a 150 year old slab of eastern red cedar from a historic homestead.  A little over 3' long, about 3" thick and extremely uneven, apparently hand hewn originally.  Client needed two parallel faces.  Tried to skim off the high spots so the blade chattered a bit at the beginning but he was extremely happy with the results.  smiley_thumbsup
Closer view
Empty view (sorry for the shadows), it can hold any length up to 9'
Can clamp at an angle and an uneven surface
Attaches to the bunks using an existing bolt.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Po-Jo
Tom I like that, going to have to save this one and build it.
justallan1
Nice work, Tom.
Looks like whatever you put on there, stays on there for sure.
Allan
Tom, that is an excellent solution.
POSTON WIDEHEAD
Look at Tom....gett'n jiggy with it. Nice tool!
gfadvm
Tom, Thanks so much for taking the time to post that! It is MUCH more secure than the one I cobbled together. And I have all the stuff I need to make yours.
Bill Gaiche
Welcome aboard. Glad you found the solution to your needs. You almost always will get the help you need on the FF. Post some photos of your latest jig and other projects. bg
gfadvm
Thanks Bill. Posting pics here has proved an insurmountable task for me. I have read all the pic posting threads but just not smart enough to "get er done". I can post pics on Lumberjocks with no problem but haven't figured FF out yet.
Computer skills are my "short suit".
giant splinter
Tom,
Solid design, looks very practical and with a few clamping options you should be able to mill just about anything that wanted.
roll with it
shelbycharger400
ive done something similar to what tom has,   with a chain slabber, you need a REAL agressive spike on the bolts due to the additional bite of a chainsaw chain, it will tear it out of the clamp system if it dosnt dig in a bit.
redbeard
I have a whole pile of channel even boxes of mounting hardware, Never occured to me to incorprate it with the mill.  And have scratched my head several times on jigs. Yours is the cats pajamas Tom nice work!. My head is spinning. Sometimes I will lay a sacrifice board on top with a heavy can't for weight and let it hang over the entry cut and it helps eliminate the chatter marks when skinning a face.
Tom the Sawyer
I have tried a piece of 'hold down' wood but in this case the top side of the slab was uneven.  The depth of cut varied from 1/8" to about an inch.  I made two passes to get the first side flat and deep enough to get a clean surface.  He was hoping to preserve as much thickness as possible so I flipped the flat face down and shaved it as closely as possible.
The jig was built of 2 - 10' sticks of unistrut, 4 short pieces of angle iron, 8 carriage bolts, assorted bolts, nuts and washers.  I used large wing nuts to tighten the moveable clamp bases.  The wing nuts are large enough to keep them from turning within the channel.  Probably the longest task in the project was grinding a 45° point on each carriage bolt.
I considered building it shorter (like two pieces from one 10' unistrut) but the mounting points for the toeboards and clamping system made that inconvenient.  It only takes about 5 minutes to mount it on the bed of the mill.  Would have preferred hex head bolts rather than carriage bolts (so I could use a small ratchet) but couldn't find any that length that were fully threaded.  Paid for itself the first time I used it.
xlogger
Tom. do you have a hard time spinning the log? I need something like that but work alone about all the time.
