Identify this one
Started by LeeB, June 20, 2017, 12:56:57 PM
LeeB
I know I've seen one of these on here before but DanGed if I can remember what it's called.
Lee,
   I don't know what it is but I saw saw that looked a lot like that all over southern Norway. The folks hooked them up to the tractor PTO and cut firewood with them. Over there they mostly cut small (4-6 inch diameter Birch) into approximately 1' lengths. They usually had a roller system they used to move the firewood and wood to palletize and shrink wrap it for sale or use.
pineywoods
Buzz Saw. They were common all over the deep south back in the late 40's and 50's. Pics in Mr. Tom's gallery. No belt guards on most of them. The blade could be swiveled to horizontal for felling, which didn't work very well. If the blade pinched in the log, Dang things would kick like a mule. They were replaced by chain saws, some of which required 2 men...Pull rope start, but most of the time, the rope got lost and pulling the belts sorta worked. I knew more than one logger who lost fingers getting them hung in the belt/pulley.
LeeB
Looks like this one was a swivel type one.
fishpharmer
Cutting edge technology in their day. (pun intended) ;D
https://youtu.be/z8HhWVzzcVc
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
That was very interesting.
TKehl
We've got one on the farm that is rough, but still has engine and some paint.  May be a bit smaller and doesn't have a fancy belt guard like that one.   ;D
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
JV
I remember the ads in the 50's and early 60's about every garden tractor company sold a saw attachment.  They claimed you could saw a winters worth of firewood with ease.
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
When I was a kid(a long, long time ago), our next door neighbor was a logger and he had several of those.  They called them cordwood saws.  They used them for bucking logs and maybe some light felling.
LeeB
So Dan, were they wind or steam powered back then?  :D
They were chipped out of flint  :D :D :D.
LeeB
Could well have been. He did light the fuse on the big bang.
LeeB
Lindy has gone to Texas this weekend so if it's still for sale it will be in my front yard next week.  ::)
Quote from: LeeB on June 22, 2017, 11:12:03 PM
That goes back pretty far  :D.
Quote from: WDH on June 23, 2017, 07:43:50 AM
I was too young to be using matches back then.
