Honda 20 seized ?
Started by sprucebunny, June 26, 2019, 09:13:46 AM
RAYAR
Quote from: sprucebunny on June 29, 2019, 03:43:14 PM
Quote from: John Bartley on June 27, 2019, 04:42:59 PM
Pull the fan shroud and see if the ignition coils are rusted to the magnets?
Yes, ignition coil(s) rusted to magnet. It turns now. Just have to figure out how to get rid of the mostly surface rust. Then I need to figure out why it always ran so crappy..... Should I just buy new coils ?
I'd rather work on a 6 cylinder anyday  :D
Do you keep this engine wrapped in plastic or non-breathable cover when not in use? This would contribute to the rusty coil condition.
Ray
mobile manual mill (custom build) (mods & additions on-going)
Custom built auto band sharpener (currently under mods)
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans (431,000 Km)
luap
You say you replaced the carb, but what about the fuel shutoff solenoid? They will  get gunked up also.
LeeB
Change the plugs. My little splitter with a honda got to where it would run about a 5 minutes and then die. Then it would start right back up. As time went on it got worse and only run maybe 40-60 seconds, backfire and then die. Changed the plug and now it runs good again.
Dana Stanley
If the coils are rusted to the flywheel, as others states, your issues may have been rust and moisture on the flywheel/coils all along. New coils, and clean the flywheel good, it will likely run like a top.
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14", 23 ton log splitter
Matthew 3:10
btulloh
Just checkin' in on your progress, SB.  Your engine must be purring like a kitten and makin' sawdust again.   8)
HM126
