Rocking Chairs
Started by LeeB, December 11, 2018, 09:35:19 PM
LeeB
My daughter is going to have my grandbaby number 5 in May. Her first child. She has requested a windsor type seat rocking chair. This is beyond my scope so I will put a post in the wanted section but wanted to give the woodworkers here a heads up that I'm looking for one.  :)
WV Sawmiller
   Good luck. I don't know the difference in a Windsor or other style rocking chair. When our daughter was in labor with our grandson on our way down to Charlotte NC we realized she did not have a rocker so we stopped at a Cracker Barrel and got her one there and it has worked well for her. They even had a non-slip cushion to fit the back and seat.
Lucky that grand baby has a Grand Father like you. They both will enjoy it.
LeeB
Lucky they got Grandma. Grampa is a tightwad.  :D
LeeB
The person behind most everything I do has found a rocking chair. Thanks anyway guys.  :new_year:
