Timberjack 230E Eaton Axle Question
Started by Mountain_d, November 08, 2022, 02:30:31 PM
Mountain_d
My 1978 230E has Eaton axles. I never had the hubs apart but someone mentioned to me that the fluid in the hubs mixes with the fluid in the differential. Is that true? Last year I put a different fluid in my hubs (not EP - extreme pressure rated - so supposed to be easier on the brass) but I ran regular 80/90 in the diffs. If those fluids do mix then I guess I was wasting my time. Maybe the turning axle moves fluid from the diff to the hubs? Any comment from anyone who has had these apart would help. Thanks.
Mountain D
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Firewoodjoe
I know mine would run back and forth. Weather it had a seal at the axle shaft or not a can't remember. But even if you put new seals in it who's to say in time the seal fails and your swapping oil again. I just ran yellow metal safe oil in the hole machine to be safe. And easy.
bushmechanic
This is correct, the oil free flows from both planetaries into the differential and vice versa. I assume you have the brass pin planetaries and not the steel ones with the needle bearings. There is a space between the axle and the housing and that is how the oil moves back and forth. When your tipped to one side the oil will run downhill to the lower planetary, then go back when leveled or tipped the other side down.
Mountain_d
Thanks for the info Bushmechanic. It would seem to me the level of the fluid in the diff is lower than the hub and thus the hub level would not be maintained, but I guess that is not the case. Yes, mine has the brass pins.
Firewood Joe, what fluid do you run? I guess the GL number is what to look for to protect the yellow metal? If anyone else can suggest a good oil for this? I didn't mind spending money on an expensive oil for the hubs as they do not take much oil, but those diffs hold a lot of stuff so it can get expensive.  I appreciate the form for questions like this. Thanks again.
Mountain D
Firewoodjoe
Ed_K
 Isn't regular 80-90 gear oil ok for brass? I use 80-90 in my gearmatic, it has a brass gear in it.
Ed K
Firewoodjoe
ehp
Mountain_d
Thanks, Firewood Joe. I will look at options from your list.
Most other loggers in my area seem to use regular 80/90 and dont seem too concerned about the yellow metal. Maybe that is how they were trained from those who worked years ago and the replacement brass components were readable available.
