Quote from: customsawyer on November 29, 2022, 06:14:02 AMGlad you were able to score some nice things. Those little forklifts don't look like much when you walk up to them but man can they lift some weight.it's a 2.5 ton, way stronger than my old 1.5 to allis.it's a 2016 but with 36k hours! that thing worked 15h/7days for the last 6 years. now it will have a easy and good life with me.yesterday i unloaded a truck, men what a difference, and now i have a side movement lever
I think it will still heat and aid drying. I would encourage you to try a well built one. You have the best wood possible for lumber, use off cuts etc. you know more than the 15 year younger self. Buy good fans and insulate so that your heat is captured and kept. Pinewoods assisted his kiln with a moderate amount of added heat. In the dry season your issue would be not drying too fast . The advantages for you vs us in VA here is the high avg temperature, I think if you carefully examine the solar kiln threads you would find some ideas that would work. Then you could build 2 more and have a set of kilns slowly and carefully drying. In a worst case you would have a need to rush and add heat.
i think i can made a solar for under 3k. do i still need a computer assisted system with inserted lecture reading pins? or is it just all manual? can i ad an outside furnace and direct the heat/smoke true the kiln with a stainless pipe and out of the other side of the kiln so it adds heat? maybe above the fans, so they suck up the heat of the pipe
It doesn't take much heat to greatly increase the carrying capacity of air.
Set the vents to maintain a moderate temperature dependent on you max allowable moisture removal rate, then dial back the temp or manually adjust the vents, not different than an old style kiln.
a question about the vents: if my outside air has 100% at 27 degrees and the solar kiln isn't a design that can heat air fast and efficient why would i want to let outside air in? isn't it way more efficient to extract with a dehumidifier? i could put two in there or a more industrial one if they can't keep up
Started by boatman on Sawmills and Milling
Started by SasquatchMan on General Board
Started by Ironwood on Urban and Community Forestry
Started by Magicman on Sawmills and Milling
