Portable diesel heater
Started by Bruno of NH, December 28, 2022, 09:49:15 AM
Bruno of NH
This is the portable diesel heater I got to pre heat Big Bob overnight for easier starting.
It's all self contained and the parts will fit back in the box.
I'm going to tarp the motor area and run this overnight.
It has a remote
I might just start it when I get up in the morning and see if that works.
Southside
That is a nice unit. How long does a tank last?
White Oak Meadows
aigheadish
I didn't know such things existed until this morning, over on the Heavy Equipment Forums, now here is the 2nd one I've seen today. Interesting how info works sometimes.
New Holland LB75b, Husqvarna 455 Rancher, Husqvarna GTH52XLS, Hammerhead 250, Honda VTX1300 for now and probably for sale (let me know if you are interested!)
barbender
I've been looking at that one, and see they also make a hot water model as well. Pretty much like the Webasto heaters I'm familiar with from the Ponsse equipment, but for $329 vs probably $2000. Probably not much parts support is the only problem.
Bruno of NH
sawguy21
I am familiar with diesel heaters but have never seen one as compact as that. How many btu's?
melezefarmer
Nice compact unit. I've been looking to get one for the sawmill shed. Their website indicates that is generates 5KW so I guess that's around 17k BTUs.
thanks for sharing.
barbender
If I actually used my skidder more, I would certainly install one of the water heaters on it. They are programmable, so you can set it for say 6:00 amn and the machine is warm when you arrive at 7:00.
tule peak timber
Nice looking unit. We are all interested in your review!
Bruno of NH
Quote from: tule peak timber on December 28, 2022, 12:24:54 PM
I have one similar running in my sawmill both for 5 weeks
It works great and sips fuel
No smell and keeps it warm
I'm sold on them
Resonator
Like Barbender said, it's basically a copy of the Webasto heaters used trucks. We had them in the sleepers because they wouldn't allow the trucks to idle all night. Big thing was the ignition elements would get dirty, (soot I think) and foul. Some could be cleaned to keep working, others they replaced the element. Also had to keep the end of that little flex exhaust pipe unobstructed. I've read some can run on kerosene, and will stay cleaner longer.
21incher
I recently put one in my side by side and it works great. It's a cheap Chinese one but no problems yet. Here is a video that basically shows it cobbed together.  Second video shows the through hull exhaust after I made the rear window at the end.  Just have to finish making doors.
Vevor 8kw Diesel Heater First Look And Mounting It In My Kubota Gizmo 850 - YouTube
Making A Lexan Rear Window For Gizmo - YouTube
charles mann
Temple, Tx
woodroe
Been watching some youtube videos on people's experiences
using these diesel heaters in shops and garages.
Seems like a good clean and cheap source of heat .
And for $150 bucks for the chinese brands hard to go wrong.
Had a woodstove in my garage but took it out for fear
of the insurance police.
Using a 35 btu kerosene torpedo heater now
and it requires some ventilation and stinks on startups .
People mostly complain about the directions and owners manual on
the chinese brand but other than that everyone swears by them even
after 4-5 years use.
Wondering if I could put one in my basement also as a backup source of heat. ?
Looking at the 8kw Vevor
models
VEVOR Diesel Air Heater All-in-one 12V 8KW LCD Remote Control for Car RV Indoors | VEVOR US
Skidding firewood with a kubota L3300.
sawguy21
Make sure you have adequate fresh air supply and vent it outside. I wouldn't do it.
Bruno of NH
I have the vevor 8kw in my sawmill booth and spend 8hrs to 10hrs a day in there.
I have a co2 monitor and have never had an issue.
I have the fresh air intake on one side and the exhaust on the other.
They put out alot of hear for a small unit.
Walnut Beast
That looks like a similar unit I seen mounted in the back bed with hose piping in the cab of of a 6 seater Polaris with a cab parked outside a bar in a small town awhile back.
