Timberjack part number
Started by Nemologger, January 01, 2023, 10:12:51 PM
Nemologger
Would anyone know the part number for the drive shaft that goes from the transmission to the transfer case on a 230D
Clean and Sober
ehp
Any driveshaft place can mark you a new one alot cheaper . The ends are very common so it's easy to be made
230Dforme
Good afternoon
Call Harold's Logging Supply
Maine 207-942-8331
Nemologger
Surely someone knows the part number
Clean and Sober
OntarioAl
Nemologger
The following are part numbers from the transmission to the
transfer case on a 230 D
1/ from transmission to bearing block 8103108
2/ Bearing block assembly 8211455
3/ From bearing block to input of transfer case 8109374
Hope this helps
Cheers
Al
Al Raman
Nemologger
Clean and Sober
