pump
Started by dnsnook, February 16, 2012, 08:45:37 AM
dnsnook
was wondering if a hydraulic pump on a skidder is the same on a fishing boat . if they are not the same and they pump the same gmp , what is the difference . i was also trying to find out if you put a little bigger pump on will it do damage to anything . thanks .
snowstorm
pump on the pot hauler? could be. some used to use vane pumps on the haulers. adding gpm can speed things up and can also cause too much heat if going too big
