Burl Processing ??
Started by nyforester, September 07, 2005, 10:27:11 PM
nyforester
I am looking for some input on the best way to process this large sugar maple burl. It is 12 feet in circumference. I have access to a wood mizer.
NOTE FROM ADMIN
pictures must be on the forestry forum server
Is it destined to be used by you, or offered for sale?   If for you, what would you do with it?
nyforester
I am open to many suggestions. I will probably use some, sell some, and gift some. Will a thick slab twist to much to make a table top ? Are cubes best ? If so, what size ? Should I just sell it the way it is ?
Dan_Shade
traditionally, I think burls were always cut into veneers because they are so unstable.  turners like blocks though, coat it with anchorseal after you cut it.
there was another post a few weeks ago about a guy that slabbed up one, you may want to check up with him to see if he has run into any problems.
but I have no real experience so take my advise for the time you took to read it, and no more!
lots of dull bands and chains
