Author Topic: Shou Sugi Ban for a squared dovetail log cabin  (Read 1099 times)
Offline w_w_w_31
  • BIG WOOD
« on: December 20, 2020, 01:45:01 PM »
What do you all think of this idea?  I am thinking about charring only the outside of the walls in order to take advantage of the preservative and fire retarding qualities of doing so.  I would brush the outside surface, and then use boiled linseed oil as the first coat to get something in the wood as a preservative, then something like Sikkens Cetol to top it off.
Trying to figure out how to keep the cabin "sealed" for warmth in the winter, I have thought about using something like a 2" gap between the logs (possibly 8"x6" or so). and also running an additional strip of wood, about 1.5"x3", between the logs with a foam strip on either side.  I would have to strategically place some screws through the logs in order to accommodate the door and window openings, probably cut out later in the process.  The additional strips between the logs would also act as backing for chinking when the time came.
dave
Your lack of planning does not constitute my emergency
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
Re: Shou Sugi Ban for a squared dovetail log cabin
« Reply #1 on: December 23, 2020, 10:12:13 AM »
Sounds cool to me.
Offline Coastallogger
« Reply #2 on: October 08, 2021, 01:38:50 PM »
Hi Dave,
I had the exact same idea. Although I wasnt sure how it would look and if it would get too hot in the summer.
Did you go through with it?
Would be cool to see.
Building 20X20 dovetail log cabin off grid.
Offline Mainecoast
« Reply #3 on: October 08, 2021, 09:42:21 PM »
All of my trim is burned pine, Doug for, and cedar...Id experiment if I was you. You can can burn almost to an alligator finish but then you cant really touch it or brush it. I pre fit all my trim, take it down and torch it. Works well. But you get covered in ash during the install. The other method I did was char it..and then wipe off the char with a red scotch pad and then oil. Its a really cool look and silvers over time. I used heritage oil when I did it.
Offline Mainecoast
« Reply #4 on: October 08, 2021, 09:43:19 PM »
Oh and Id use pure raw tung oil. Doesnt the boiled linseed almost mildew over time?
Offline mattgancz
« Reply #5 on: October 09, 2021, 07:14:18 AM »
I have used both tung oil and linseed oil.  Linseed oil has more of a propensity to yellow when compared with tung oil in my experience.  No reports of mildew from my end.
Offline Don P
    • Calculator Index
« Reply #6 on: October 09, 2021, 08:23:05 AM »
I started writing, hit wikipedia to fact check and their article is excellent, especially the last section on raw linseed oil, stand oil, and boiled linseed oil.
In our humid climate raw linseed on old barns and such just becomes a moldy black mess, boiled linseed oil at a minimum but it is not really ideal, at least here.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline Mainecoast
« Reply #7 on: October 09, 2021, 08:27:25 AM »
Thus the raw tung oil...I almost never use linseed oil. I like to cut my tung oil with turpentine. The boat builders almost always use raw tung oil.
Experiment with the brushing in burned wood. Getting the right texture is the key. And something you can replicate over and over.
You could always use heritage natural oils they have a copper mildecide in the outdoor version I believez
Offline ShimodaLife
  • Clearing land and timberframing in Japan
    • Shimoda Life
« Reply #8 on: October 12, 2021, 02:44:58 AM »
I did that on my TF tiny house in June. But I did the outside planks, not the frame itself. The burning was surprisingly easy and quick. The sealing went well; I used Tung oil cut with mineral spirits.
I did two videos on it; I think this is the first one:
Cheers,
JT
Completed my Timber Frame Tiny House as practice for the soon-to-be-started TF Real House. Tracking all on my Shimoda Life Youtube channel.
Offline flyingparks
« Reply #9 on: October 19, 2021, 11:02:48 PM »
Thanks for your videos. Watched, enjoyed, and learned.
Offline Joe Hillmann
« Reply #10 on: October 21, 2021, 10:39:52 AM »
The problem I have with methods like this is, you can find tons of partial information on it all over the web and you can find all sorts of videos of people showing how they did it.
What you don't see is people coming back 5/10/15/20 years later with any updates of how it is holding up.  For all we know it only lasted 5 years, began to rot and they ripped it off but never updated the original video talking about how good it was.
It is also hard to find full information on the traditional way to do it.  Things like: what type of lumber, in what climate, what type of oil they used in history, what the normal maintenance on it is, do they use the entire tree or just the heartwood or just the sap wood, does it work with ground contact or does it have to be well protected.  All that information tends to be missing when I see blogs and videos of people saying how wonderful the method is.  I would think wood type makes a huge difference, white oak, cedar, locast and old growth pine  will all probably last much longer than poplar, maple, basswood, and pine sap wood.
Shou Sugi Ban used on a cabin exterior
Started by ahuntington on Drying and Processing
Last post November 19, 2021, 11:21:44 AM
by ahuntington
Shou sugi ban
Started by nativewolf on Drying and Processing
Last post November 16, 2020, 11:34:36 AM
by nativewolf
shou-sugi-ban fence/with door
Started by Lawg Dawg on General Woodworking
Last post June 22, 2015, 07:48:59 AM
by Jemclimber
Shou Sugi Ban (charring) fresh sawn eastern white hemlock
Started by woodland84 on Drying and Processing
Last post July 31, 2020, 10:17:44 AM
by GeneWengert-WoodDoc
