Author Topic: Sawing frozen wood  (Read 1869 times)
Offline Andries
  • Making buildings out of big curvy logs
Re: Sawing frozen wood
« Reply #40 on: November 29, 2021, 08:33:14 PM »
Woodmizer will probably contact you to use that photo in their promotional material.
You take a great photo MM, thanks for thawing out your hands long enough to capture the moment!
LT40G25
Ford 545D loader
Stihl chainsaws
Offline Bruno of NH
« Reply #41 on: November 30, 2021, 06:45:28 AM »
How bad were the black flies this morning Bruno?
7į this morning it will keep the black flies down  :D
Offline Southside
    • White Oak Meadows
« Reply #42 on: November 30, 2021, 07:20:06 AM »
We'll see, now that's an improvement and something to look forward to in winter.  :D  :D  :D
White Oak Meadows
Offline Joe Hillmann
« Reply #43 on: December 01, 2021, 03:11:53 PM »
. . . wet sawdust would build up a thick layer on the blade guides.  .   .
Joe, were you using blade lube at all?
Windshield washer fluid (-40 rated) works well at keeping the blade clean and an added bonus is that the sawdust doesn't freeze up on guides and between boards.
It aggravating to have to pry-bar the boards apart.
I was using diesel.  However with my mill if I flood the blade with too much lube the blade likes to come off the wheels.
Offline Quebecnewf
« Reply #44 on: December 02, 2021, 02:10:07 PM »
I donít saw in the winter months . Just too much trouble dealing with snow and ice on the logs . Plus the mess you make  with the slabs covered in ice , naw not doing it .
Now that being said I log in the winter . Best time ever in the woods is about -15C and a sunny day .too cold to sweat so your just good as you work
Quebecnewf
Why is this wrong way up I donít know . Adm will fix Iím sure
Offline Tacotodd
  • To learn and help
« Reply #45 on: December 03, 2021, 09:22:09 AM »
Q, Iíd guess that your Yammy skidder works well. Rails, skids, orÖ?
Trying harder everyday.
Offline fluidpowerpro
  • Hi there!
« Reply #46 on: December 14, 2021, 08:20:12 PM »
Now Fluidpower, what part of MN are you in that they are calling Jack Pine, Red Pine? I won't have it!😊
Sorry, been away so not able to visit the forum as often as I would like.
Forgive my ignorance. I thought they were the same. I hang out most of the time near Holyoke, 30 miles south of Duluth.
A few years ago I bought 20 acres down the road that was former Potlatch land, so whatever pine they planted, thats it....
Change is hard....
sawing frozen wood
Started by Qweaver on Sawmills and Milling
Last post February 23, 2006, 08:28:25 AM
by Troy
Sawing frozen wood
Started by dirtmover2 on Sawmills and Milling
Last post January 16, 2022, 11:05:14 AM
by dirtmover2
Sawing Frozen Red Oak
Started by Knute on Sawmills and Milling
Last post January 07, 2011, 07:05:36 PM
by terrifictimbersllc
Sawing frozen oak
Started by sprucebunny on Sawmills and Milling
Last post December 07, 2007, 02:09:33 PM
by SwampDonkey
