Hydraulic pump selection.
Started by Satamax, December 22, 2017, 04:33:33 PM
Satamax
Hi everybody.
I need to choose an hydraulic pump for my Latil.
I have a pto on the gearbox. Dunning from 800rpm at iddle, or thereabouts. To 2200 rpm aproximately at full speed.  I will have 4 rams to power, not at the dame time. Two for the blade. Two for the log basket.  I might add a little crane at a later date.  I have a 180l tank i can use.  What kind of gpm would i need? What do i choose? Piston, swash plate, gear? Something else?  My pto is disconectable if ever i really need to. And the coupling  flange is running counterclockwise when looking at it.
Thanks guys.
French CD4 sawmill. Mecalac digger, with grapple. Self moving hydraulic boom crane. And a Brimont TL80 CSA.
arthurjohnston
Hello, did you try to search online at some manufacturer and just ask for qualified assistance?
Satamax
Thanks a lot Arthur. The latil is long gone now. Post is from 2017.
scsmith42
Quote from: Satamax on January 08, 2025, 01:46:11 AMThanks a lot Arthur. The latil is long gone now. Post is from 2017.
so, which pump did you end up using 8 years ago? lol
Tom's 3638D Baker band mill
Satamax
Nothing. Project was another of my failures!  smiley_crying
