gearmatic 19
Started by treefarmer rick, January 10, 2013, 06:23:35 PM
treefarmer rick
hello all, was wondering if anyone knows the proper adjustment of the "adjuster bolt " on the inside of this winch. It is about 2-3 inches long with a jam nut on it. thank you.
coxy
i just titen the ajuster till it is snug dont no if it is right or not never had any truble i have 3 19 119 119
Ed_K
 I do The same as Coxy,never had a problem with the secondary band.It's hard to get the primary set tho.I use a hacksaw blade to set it.
Ed K
HiTech
Brake adjustment.  To adjust, pressurize brake cylinder for free spool and turn setscrew clockwise until it contacts lever block. Return the control valve to neutral then add half a turn to setscrew. Hold setscrew and tighten jamnut.
