Author Topic: 066 no running right - please help  (Read 1954 times)
Offline Dangerous_Dan
  • Poor planning on your part does not constitute an EMERGENCY on mine.
« on: January 30, 2005, 09:19:52 PM »
I've got an 066 that starts and runs but will not idle and bogs badly at low rpm. No amount of tuning has corrected the problem. What seems to be an indication to the real problem is that when running with the air filter off a spray of fuel and air is coming out of the carb.
Any ideas on what the problem could be?
I have another 066 I can use for parts. It runs perfect but the engine case is cracked for the oil tank. I can swap whatever turns out to be the problem.
Where do I start?
First you make it work, then you trick it out!
Offline Lucky
Re: 066 no running right - please help
« Reply #1 on: January 30, 2005, 09:32:32 PM »
Hi Dan.  Swap the carb and see if that helps.  Otherwise you might have an air leak somewhere, and have ot fix it before the saw will run right.   John
Offline dansaylor
« Reply #2 on: February 01, 2005, 06:08:46 AM »
Try taking the screen out of the muffler my uncles 272 did the same thing and the screen was stoped up....if that works buy a new screen....sounds like more of the problem to me also had a green machine trimmer do the same thing....hope that helps will save some money also to check it first.
Offline Busy Beaver
« Reply #3 on: February 01, 2005, 11:21:44 AM »
DD.....pull your muffler and check your piston for a heat score. If it has one you could have a stuck ring.
BB
Offline Sawyerfortyish
  • Bigger they are the more mess they make
« Reply #4 on: February 06, 2005, 08:30:41 AM »
I bought a 064 that spit gas out of the carb and sometimes would preignite when pull starting and just about take your arm out of the socket. I did everything  couldn't get it to idle or set it up to run right. Sent it to a stihl tech and had his head spinning. It took someone to go through the saw piece by piece to figure out what was wrong. At some point in the saws life before I got it someone switched the magnetto. The timming of the saw was wrong. that caused gas to blow out the carb and the preignition. So if this saw is one you don't know the history of and you have a parts saw. Try switching the mag out with the one in the part saw and see if that helps
« Reply #5 on: February 09, 2005, 09:38:06 AM »
It's Fixed!
As advised I took the muffler off and the first thing I noticed was the baffle had broken. The broken piece and some little bits were inside the muffler rattling around.  Through the exhaust port I could see the top ring was stuck.  Took the cylinder off and it looks like the piston hit some small metal bits probably from the muffler and pinched the top ring. I swapped out the piston and cylinder from the parts saw and it's running great.
Thanks to some great advice from the FF chainsaw guys,it's back in action!
Thank you,
DD
Offline Busy Beaver
« Reply #6 on: February 11, 2005, 02:04:24 AM »
BB
Don't mention it! BB
What does it take to keep a saw running?
Started by cnl390 on Chainsaws
Last post August 17, 2011, 04:27:22 PM
by shelbycharger400
HM 126 up and running!
Started by woodcat47 on Sawmills and Milling
Last post May 05, 2016, 10:17:20 AM
by JamieT
Up a Running
Started by Firebass on Sawmills and Milling
Last post March 25, 2007, 10:32:38 AM
by Captain
Up and running
Started by Osterman.r on Sawmills and Milling
Last post July 21, 2021, 01:51:13 PM
by Osterman.r
