Author Topic: Critter pruning my Red Oak  (Read 936 times)
Offline Chuck White
  • Sawing Mobile 2005-2022
« on: August 27, 2020, 10:19:08 AM »
Seems like most mornings lately I have quite a few small branches on the ground around a 10" DBH Red Oak in my yard!
I've gone out and checked, and the branches are only about ¼" dia, and had some acorns on them, but most of the acorns have been eaten!
Seems to happen through the night or very early in the morning!
I laid the blame on squirrels, but I haven't seen any, just wondering if Racoons do such things?
Maybe I need to shine the tree late at night sometime!
Is this a weird or common occurrence?
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, Retired Mobile Sawyer 2022, 2018 Silverado 4X4,  2019 Subaru Forester.  Cooks Cat Claw Sharpener and single-tooth setter
Offline thecfarm
Re: Critter pruning my Red Oak
« Reply #1 on: August 27, 2020, 10:24:34 AM »
Nope not odd at all for a porky pine.  ;)  Put a piece of tin around the tree to stop them from climbing up the tree. They cut the acorns off and than climb down the tree and eat them.
Offline Chuck White
« Reply #2 on: August 27, 2020, 01:43:16 PM »
Hadn't thought about Porcupines!  smiley_lit_bulb
They're usually SSS to!
~Chuck~
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: August 27, 2020, 09:45:05 PM »
Squirrels.  Look for an accumulation of branches/leaves stuffed in a crotch above the fallen branches.
Offline KEC
« Reply #4 on: August 27, 2020, 10:12:41 PM »
Here in Onondaga County, New York I saw this with gray squirrels often. I think they clip branches for nest material and often they accidently drop to the ground, then they clip another one. It's a little late, but grays have a litter in early spring and another late summer. Females build a new nest off by herself to have the litter.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #5 on: August 28, 2020, 06:38:38 AM »
Probably twig miners.  Are the twigs cut clean with a slightly rounded end?
Offline Chuck White
« Reply #6 on: August 28, 2020, 07:53:57 AM »
Exactly as WDH suggests, twigs are cut clean with a slightly rounded end!
It's clear though that the small branches are cut, then the culprit comes down and eats the acorns!
There's lots of shells and bits of acorn right where the branches lay!
I'm going to put the gamecam out there today!
~Chuck~
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: August 28, 2020, 11:05:52 AM »
I am familiar with twig miners and that is not what I have.
Twigs sheared off.  (Fuzzy and out of focus pictures but you can still see the diagonal cut.)
And directly above are two freshly built squirrel nest.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #8 on: August 28, 2020, 04:31:48 PM »
   One thing about leaf nests that always amazed me was the way the leaves cured to a leathery texture inside. If the same leaf fell on the ground it would normally dry up and get brittle but the ones inside the nest stayed soft and pliable. Down in Dixie County Fla where why grandparents lived the nests there seemed to be lined with Spanish Moss. I guess squirrels are immune to Redbugs. :D
WM LT35HDG25(2015) , 2009 4wd Dodge PU, Kawasaki 650 ATV, Stihl 440 Chainsaw, homemade logging arch (w/custom built rear log dolly), JD 750 w/4' wide Bushhog brand FEL
Offline Ron Scott
« Reply #9 on: August 28, 2020, 05:14:18 PM »
Usually a squirrel activity, but raccoons and porcupines may do it also. See what the game camera catches.
~Ron
Offline WDH
« Reply #10 on: August 28, 2020, 09:39:27 PM »
I suspect that in Chuck's case, the leaf miners are dropping the twigs and the squirrels are taking advantage of easy pickings.  Lynn's situation seems to be more of a direct, cold calculated, deliberate squirrel raid to make it easy to get the acorns.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #11 on: August 28, 2020, 10:06:48 PM »
No, they are building nests.  They always drop a few limbs but sometime the whole thing falls out and they have to start all over again.  There are a half dozen or so nest that have been built within the past few weeks both in the Red Oak in the back yard and White Oak above the drive.
They take whatever acorns that they want directly from the limb but they have not begun to eat acorns yet.  Now it is Pine cones and Beech nuts here at my place.
Offline Chuck White
« Reply #12 on: August 29, 2020, 08:04:05 AM »
Still no additional activity out there, so I'll leave the game cam a couple more days!
This situation isn't leaf mining, the leaves are still on the branches, the only thing missing are the acorns!
~Chuck~
Offline Chuck White
« Reply #13 on: August 30, 2020, 03:14:35 PM »
Checked the game cam today and the only critters out there were a doe & fawn!
They did a pretty good job of cleaning up the left over acorns!
They were out there for about 45 minutes!
~Chuck~
Offline KEC
« Reply #14 on: September 04, 2020, 11:29:44 PM »
Several years ago, my son and his buddy and I went deer hunting on Ft. Drum in Northern, N.Y. I came upon a hemlock tree with many small twigs with green foliage on the ground under the tree. I looked up to see a porky sleeping on a limb (it was 17 degrees F). He chose a cold place to nap. It occurred to me that in areas like the Adirondacks with mature forests that the porkies are probably helping the deer  by cutting browse for them.
Offline Ron Scott
« Reply #15 on: September 07, 2020, 09:39:21 PM »
Yes, I've seen them work that way. The deer will clean up the fallen foliage from the porky's chewing.
~Ron
