Author Topic: Is the Woodwmizer Debarker worth the money?  (Read 678 times)
Offline dogbo2013
« on: June 13, 2021, 07:25:27 AM »
I have ordered an LT40 and added the debarker, but now I'm wondering if it's worth the money. I have limited experience running an LT40 with a debarker, but it seemed to be more of a hassle than it was worth when I did. It was hard to adjust and keep adjusted to an irregular log. It bit in too far several times causing the blade to stop and trip the breaker. I know that it should help extend blade life, but how much? At almost $2000 for the upgrade, would it be cheaper to just replace the blade a little sooner?
GMB
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Is the Woodwmizer Debarker worth the money?
« Reply #1 on: June 13, 2021, 07:30:18 AM »
The debarker significantly extends blade life.
I'm very glad that I have one on my LT-40
Dan
lots of dull bands and chains
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: June 13, 2021, 07:31:35 AM »
I have found the debarker to be invaluable to me.  I would hate to saw without it.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: June 13, 2021, 07:41:26 AM »
With my portable sawing profile and always sawing customer's logs, I would hate to even think of sawing without a Debarker.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: June 13, 2021, 07:58:56 AM »
Takes a little while to figure out when it comes to adjusting the debarker, but it takes patience!
Once you figure it out, there's really nothing to it!
I'm very happy there's one on my mill!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Sixacresand
« Reply #5 on: June 13, 2021, 08:08:15 AM »
They should have called it a "de-dirter".  It definitely cleans up nastiness in front of the blade.
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum
Offline Southside
    • White Oak Meadows
« Reply #6 on: June 13, 2021, 09:07:02 AM »
I removed the debarker on my 35 for a little while, the difference in band life was night and day. I use the one on my 70 constantly.
White Oak Meadows
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #7 on: June 13, 2021, 10:28:08 AM »
It does dig in and stop, trips the breaker, but most of the time it sprays chips and works great. I found that the breaker was weak and replaced it, reduced the amount of breaker tripping. I just upgraded to the 1/2" blade on my debarker. I ordered a new one so I can take the old one in for sharpening. I use mine all the time. I also modified mine in that I took the V yoke off so it will fit around the big ugly logs I mill
Offline Lasershark
« Reply #8 on: June 13, 2021, 12:47:48 PM »
We call the debarker a "mudsaw" around here. I find that I'm very active with the armature controls as I dodge knots and adjust tension to suit the diameter of the log. The only time I've had to reset the breaker was when I engaged the blade after the saw was in the wood. You want that thing spinning beforehand! And that means engaging the forward gear.
2020 LT-50 Wide, 38 HP Gas, with debarker, lubemiser and laser sight,  2002 Dodge Ram, Husquvarna 365 chainsaw, comealong, couple cant hooks and a strong back.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #9 on: June 13, 2021, 01:58:19 PM »
Iíd say the debarker doubles sawing time on a blade sometimes more than doubles it.
In some cases it saves a blade.  The gritty bark is one thing but dirt and small rocks can end a blade quickly.
The debarker will pay for itself over the course of 3 or 4 boxes of blades.
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline curved-wood
« Reply #10 on: June 13, 2021, 03:20:46 PM »
I have a debarker on my lt40 and I don't use it anymore. Most of my logs are bought in winter or with few professional loggers so the logs are clean. When I was on the road with the mill , a debarker is essentiel. Most people don't care about the gravel on their logs. I remember a customer had some logs so dirty , I asked how he skidded. Well, he had a small 9N Ford tractor nd very steep land, so at every bottom of the trail , he would slack the logs in the mud hole, and after the tractor was on top of the hill, he was winching the logs back. I don't know if you could skid some logs dirtier. Anyway, I don't use the debarker anymore. It's  always a matter of adjusting your production accordingly
Offline OlJarhead
« Reply #11 on: June 13, 2021, 07:00:13 PM »
Yup, wouldn't want a mill without one!
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #12 on: June 13, 2021, 07:09:42 PM »
It depends on how much you'll saw and how much of that is not clean wood.  If you're in business the debarker and other upgrades pay for themselves over time some sooner than others.  If you're going to use 100 sharp blades over the life of your mill instead of 50 then probably not worth it.  If you use 50 sharp blades in a week or two then the debarker means a great deal less work and expense with blade maintenance.  And on top of that saves time during a sawing day not changing blades and not sawing slower to keep cuts flat.  It also improves the quality of your work.  If you fly through logs with flat cuts you can focus your attention on other sawing techniques that give better lumber.
Offline Beavertooth
« Reply #13 on: June 13, 2021, 07:36:37 PM »
Had a LT40 without debarker  and have had a LT70 for 13 years with it .. Would definitely hate to have to saw without it ..
2007 LT70 Remote Station 62hp cat.
Offline barbender
« Reply #14 on: June 13, 2021, 09:33:27 PM »
Curved-wood, if you want to get that clunky ol' useless debarker off your saw head and lighten it up, I can get you my address. I will dispose of it properly😁
Offline Southside
    • White Oak Meadows
« Reply #15 on: June 13, 2021, 09:59:04 PM »
Do you have photos of the mod you are speaking about?  How do you like the thicker blade?
White Oak Meadows
Offline Polish Hammer1
« Reply #16 on: June 13, 2021, 10:04:43 PM »
I saw with a low budget manual mill without a debarker and have sawn with an lt40 enough completely different  machines I know but band life is incredibly better with the lt40.. and thatís with running the same red streaks bands on both
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #17 on: June 13, 2021, 11:50:36 PM »
Before I got a mill with a debarker, I pressure eased every log. I like my debarker better
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline dogbo2013
« Reply #18 on: June 14, 2021, 06:11:30 AM »
Thank you all for responding. I value and trust the opinions of this forum!
Offline curved-wood
« Reply #19 on: June 14, 2021, 07:22:54 AM »
lol Ok I will think of you to get rid of my old clunky useless debarker
Debarker for the lt-35 worth it?
Started by hunz on Sawmills and Milling
Last post December 13, 2013, 05:37:37 PM
by hunz
Our Money's worth
Started by WV Sawmiller on General Board
Last post August 18, 2020, 03:34:09 PM
by Old Greenhorn
Well worth the money!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post April 06, 2012, 04:39:15 PM
by Amelia Farms
Edgers. Are they worth the money?
Started by TnSawyer on Sawmills and Milling
Last post March 01, 2007, 07:48:36 AM
by Faron
