Author Topic: 76 674 international  (Read 1088 times)
Online mike_belben
  • Pulp Friction
Re: 76 674 international
« Reply #20 on: June 19, 2021, 02:55:35 PM »
When you put the king quad back together, put a $10 aftermarket fuel petcock.  The vacuum one is trash.  Also delete the fuel pump under the fender.. Just run a line out of the tank to a clear filter to the carb.  Blow in the vent hole to prime it first time and plug the extra carb ports.  Otherwise these notoriously drain the gas into the engine until its full. Youll have a lot of new junk oil to burn that way.
Oh and saw the bolt feet off back of the airbox.  Theyre terrible to get in.  I put a generic starter solenoid on the rack with a lawn battery so i never have to pull plastics again!
Proverbs 19:11
Online HemlockKing
« Reply #21 on: June 19, 2021, 04:55:20 PM »
Nice ride.  What motor and injection pump?
Diesel. Im not even sure on the injection pump. Im gonna be learning a lot about it shortly though lol
Online HemlockKing
« Reply #22 on: June 19, 2021, 04:57:16 PM »
Oh its been together for over a year. I believe when I put it back together I capped the vacuum to the carb and just bypassed it. I remember thinking what in the heck with this contraption, just give me a normal design
Online mike_belben
  • Pulp Friction
« Reply #23 on: June 19, 2021, 07:18:43 PM »
Keep tabs you arent 'makin oil' in the site glass.
Proverbs 19:11
Online HemlockKing
« Reply #24 on: June 20, 2021, 05:46:52 AM »
Looking to change the hydraulic fluid. I cant find a service manual. Is this the drain plug for the hydraulic? And I understand this uses hy-trans fluid? I assume the power steering is powered by that too? Thanks anyone who can help .
Offline thecfarm
« Reply #25 on: June 20, 2021, 05:51:39 AM »
Good luck with the tractor.
Online HemlockKing
« Reply #26 on: June 20, 2021, 05:59:24 AM »
Thanks c farm. Its exciting. Its my first big piece of machinery.
Offline thecfarm
« Reply #27 on: June 20, 2021, 10:10:30 AM »
That looks like a deep bucket. Sure was not used to dig rocks with.  ;D
Online HemlockKing
« Reply #28 on: June 20, 2021, 10:19:31 AM »
Its definitely a big bucket, it needs a bit of work, rusting away in spots, still lots of integrity though, I filled it with stones to fill parts to the woods road so far.
Online HemlockKing
« Reply #29 on: June 20, 2021, 10:22:22 AM »
I am needing to do a few hydraulic fitting repairs. It seems fluid from there on the 3 pt and one side of the front end loader. Hopefully just o rings
Online mike_belben
  • Pulp Friction
« Reply #30 on: June 20, 2021, 03:58:21 PM »
On SAE fittings it probably is just the O ring.
Proverbs 19:11
Offline farmfromkansas
« Reply #31 on: June 20, 2021, 04:12:45 PM »
The drain plugs for the hydraulic rear end and trans oil are in the bottom.  Think I had to take about 4 plugs to get it all out of my 986.  And the replacement oil from Case is Hy-Tran, for hydraulic transmission fluid.  I bought my oil from NAPA this spring, they have a yearly oil and filter sale.  You can also use HG fluid from Phillips 66, many other oils, think the cheap oil from some farm supply stores has been sued out of business, got a check from some law firm for 20 bucks from some oil I bought at Orsheln supply to put in my log splitter. Change the filters as well. If you have a Case dealer nearby, they could show you what filters to change, if they are any good.  Went to my Case dealer one time, asked to see the repair manual on my skidsteer, which I bought from them, they would not let me see it.  Haven't bought any more case equipment either.
Online HemlockKing
« Reply #32 on: June 20, 2021, 04:24:56 PM »
Thanks for the info. Nearest dealer is 3 hours away unfortunately. Napa it is. Hopefully they have the hydraulic o rings too. How can they not. Small town Napa store though lol
Online HemlockKing
« Reply #33 on: June 20, 2021, 04:26:02 PM »
For motorcycles and atvs incan usually find a free pdf version service manual but I cant seem to find one for this tractor, I may cave and spend the 30$ for one
Online HemlockKing
« Reply #34 on: June 20, 2021, 04:51:02 PM »
Well I must say, the yellow jackets love the tractor. It was a battle all day with them lol
Online mike_belben
  • Pulp Friction
« Reply #35 on: June 20, 2021, 11:17:09 PM »
Dont get raked over coals on the O rings.. Nothing special.  I got charged $13 each on 2 itty bitty generics at case a few year ago.  Coulda bought 1000pcs of the same chicom generics @ HF for that.   Ive used the HF junk on many many hydraulic parts over the years without issue.
Proverbs 19:11
Online HemlockKing
« Reply #36 on: June 21, 2021, 05:02:36 AM »
What is the abbreviation HF?  :)
Offline thecfarm
« Reply #37 on: June 21, 2021, 05:19:52 AM »
Harbor Freight. A cheap place to buy tools. Some of the tools are cheap and will break with hard usage, but some OK for only a year usage. I buy black electrical tape and the steel cutting blades for a saw. A great place to buy cotter pins too.
Online HemlockKing
« Reply #38 on: June 21, 2021, 06:11:30 AM »
Our place of cheap tools is Canadian tire. No HF here. Or princess auto which is my usual
Online HemlockKing
« Reply #39 on: June 21, 2021, 09:12:18 AM »
 Got some cross threading action going on here seems to be a culprit too. I assume they sell these fittings at part stores?
International sa8
Started by loggerman1959 on Forestry and Logging
Last post August 27, 2015, 06:10:18 PM
by lynde37avery
International TC5 or here we go again
Started by svart ole on Forestry and Logging
Last post October 10, 2019, 08:11:01 PM
by Gearbox
International s8
Started by 70amxguy on Forestry and Logging
Last post April 10, 2021, 05:20:08 PM
by bushmechanic
International S7C Log Skidder
Started by Dale Hatfield on Wanted
Last post September 15, 2009, 11:15:56 PM
by jerryatric
