Author Topic: Price to pull tranny, replace transfer case & torque converter, labor only  (Read 957 times)
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
alrighty, just wondering which ya guys think is a reasonable price to do that on an 04 chev 2500? No parts, they just provided the labor. It has the allison tranny. Replaced the front and rear tranny seals also. thanks
Offline alan gage
Re: Price to pull tranny, replace transfer case & torque converter, labor only
« Reply #1 on: September 01, 2021, 10:09:23 PM »
If you came to my shop I'd charge $1250 labor for pulling the trans and replacing the front and rear seals. I'd probably add another hour for replacing the transfer case and torque converter at the same time for a total of $1375+tax.
This is assuming I was selling you the transfer case and torque converter. If you were supplying parts the labor would be higher.....actually more than likely I would decline the whole job.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Offline Iwawoodwork
« Reply #2 on: September 01, 2021, 10:16:16 PM »
in this area  independent mechanic shops are about $100 +- per hr.. The dealer shops are pushing $125-150 per hr.    The small at home mechanics are about $75 +-.
Offline chevytaHOE5674
« Reply #3 on: September 01, 2021, 11:15:20 PM »
I'd guess 8 hours to pull the trans, replace seals, and reinstall. Add an hour for monkeying with the transfer case (praying the bolts aren't corroded into the aluminum and cause a fit).
So 9 hours at 125 an hour is $1125.
Like Alan said thats assuming I'm sourcing the parts. If your bringing parts in then I most likely would turn down the job. Had a few too many jobs come back when the customer sourced poor quality parts. Only exception to that rule for me is aftermarket parts that are known good quality (ex Air Dog lift pump on a cummins).
Offline Sedgehammer
« Reply #4 on: September 02, 2021, 12:06:50 AM »
Thanks everyone thus far.
They don't supply any parts. Customer buys them. They said $1,100.
Offline sawguy21
« Reply #5 on: September 02, 2021, 03:00:27 PM »
I tried replacing a fuel pump by dropping the tank, ran into problems I couldn't handle without the proper tools so nursed it to a shop. They installed my aftermarket pump but it failed two days later. They were good about it, exchanged the pump themselves and got me going but I paid the additional labor. Lesson duly noted and filed for future reference. ::)
Offline alan gage
« Reply #6 on: September 02, 2021, 03:40:55 PM »
Exactly. I wish I could say the parts we install never fail (or turn out to not fit) but at least if we're the ones that sold the parts there's no question on who is paying for it (us). Just suck it up, get another part coming, do it again for free and move on to the next job.
When it's a customer's part you have to let them know and then they have to go back to wherever they bought it and get another one. In the meantime (sometimes days) you could have a hoist tied up with a disassembled car waiting for them to get the replacement part.
Had a Subaru come in last week with a bad alternator. Customer had replaced it himself 2 months ago. He asked if we'd install the warrantied alternator if he brought it in. We told him we would and then waited a week for him to get it and bring it to us. Not a big deal since the car wasn't torn apart and was sitting out in the parking lot but we can't deal with that stuff on a regular basis.
Alan
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #7 on: September 02, 2021, 11:24:47 PM »
A couple of years ago the in-tank fuel pump failed on my F350 dually.  I had to have it towed in to a independent shop where it had been worked on several times.  When they called to tell me it was ready, I was shocked when I went to pick it up.
The mechanic explained that my 40 gallon fuel tank was almost full so they had to drain it, which took awhile, then one of the tank straps was corroded so they had to replace that, as I recall the fuel pump was a bit over $100, then they had to reinstall the tank, and refill it, which took most of the day.  I said that certainly explained why the labor costs were so high.  I then opened the driver's door and pressed the button which raised the flatbed dump to its full extension and where you could reach the top of the fuel tank by hardly bending over.  How he missed the frame-mounted hydraulic pump, or the huge hydraulic lifting cylinder and scissor mechanism, while laying under the truck remains a mystery.  smiley_speechless
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Offline Tacotodd
  • To learn and help
« Reply #8 on: September 03, 2021, 10:16:44 AM »
Tom, everyone misses easy stuff periodically. We’ve ALL done it. Lord help me I know that I have.
Similar to the time I thought my chainsaw oil pump went out. Turns out I forgot to put bar oil in (kinda helps to lube BC combo with oil :embarassed:).
Trying harder everyday.
Offline farmfromkansas
« Reply #9 on: September 03, 2021, 08:10:56 PM »
I had to have the fuel pump replaced on my 05 F-450 flatbed.  The PO welded in a receiver hitch on the rear, and you can't get to the bolts so you could lift up the flatbed.  So luckily the gas tank was very low when the pump quit, and I got a friend to help me tow the truck to the shop.  Bill was 826. plus change.  Price of pump was over 500.  Now the truck starts quicker and has more power at low speed, so turned out to be good to replace it.
Offline Sedgehammer
« Reply #10 on: September 04, 2021, 08:19:41 AM »
I did get them to come to an even $1,000.
Offline alan gage
« Reply #11 on: September 05, 2021, 09:00:18 PM »
That would have been an interesting conversation to hear:
"I asked around and everyone said they'd charge more than you. Do you think you could do it for less?"
Alan
Offline Sedgehammer
« Reply #12 on: September 05, 2021, 10:30:03 PM »
Alan
:D oh it was good. For us anyways.  ;D
It was cash, so there's that also
question
Torque converter pullapart
Started by JustinW_NZ on Forestry and Logging
Last post May 15, 2018, 12:48:31 AM
by JustinW_NZ
Coupling/torque converter
Started by MakitaCS on Chainsaws
Last post December 31, 2008, 08:21:42 PM
by MakitaCS
clark 664 torque converter question
Started by rockwall on Forestry and Logging
Last post October 23, 2016, 05:40:45 PM
by treeslayer2003
rebuilding a clark torque converter
Started by krusty on Forestry and Logging
Last post May 13, 2020, 11:36:38 PM
by krusty
