Author Topic: Zero turns mowing wet grass?  (Read 1030 times)
Offline gspren
« on: September 11, 2021, 02:29:27 PM »
  I'm in the thinking stage which is dangerous  :D, My 20 year old JD 345 with 48" deck has been strong and dependable but likes the grass to be very dry or it clumps. I've got a near 30 year old Exmark walk behind zero turn that will handle wet grass fine but my bum ankle won' allow too much mowing with it. Any recommendations for a 54" mower that don't mind early morning mowing? I think @Spike60 sells Exmark and there is a dealer not too far away but I don't know if I'd believe what he said. I'm open to any brand.
Stihl 041, 044 & 261, JD 2355 4X4 w/fel, JD 620, Yamaha Kodiak 400 & trailer, Kubota 400 RTV,  P&M OWB, 75 acres to play.
Offline Gary_C
  • Sunrise on the Prairie
Re: Zero turns mowing wet grass?
« Reply #1 on: September 11, 2021, 02:54:51 PM »
I tried a Husky with a 54" deck and a mulcher attachment and did not like it because it makes a mess of the deck. I don't think there are any mowers that handle wet grass without extensive cleaning. The Grasshopper mowers have a flip up deck for easy mowing under shrubs, etc and they make for easy cleaning.
I've got a Husky Commercial 60" zero turn and it mows most anything including grass in water (till the water gets too high and bogs the engine down) but if I mow in wet grass it usually needs a cleaning afterwards and it is a pain as I have to use a chain hoist to get underneath. It will cut fine but you are going to pay.
I had a cub cadet with nozzles on the deck for cleaning but they did not work worth a crap.
I just looked at a local dealer that usually has a lot of both new and used inventory and he has practically nothing. It's going to be hard to find any selection right now.
Offline doc henderson
« Reply #2 on: September 11, 2021, 03:19:15 PM »
I have a walker 52 inch with an integrated aux. blower.  I agree, all mowers do better if the grass is not dripping wet.  this is considered a commercial mower.  the deck tips up.  uses two blades that turn opposite.  it is also easier to make a spin bare spot if the yard is wet.
Offline Southside
    • White Oak Meadows
« Reply #3 on: September 11, 2021, 03:32:33 PM »
A disc mower, like used to mow hay, will cut wet grass. Not sure if anyone offers that cutter style in a zero turn.
Would make blade sharpening a lot easier.
Offline sawguy21
« Reply #4 on: September 11, 2021, 03:47:10 PM »
I am not sure leaving swaths is what he wants. I have tried zero turns in wet grass, used to sell them, and didn't find any that worked satisfactorily. My experience was with Exmark, Toro, and Husqvarna, ymmv.
Offline alan gage
« Reply #5 on: September 11, 2021, 03:50:31 PM »
I think it's a deck design issue. Toro is a very popular brand here and they were very bad with clumping and on some it took very dry grass to keep it from building up under the deck. Very frustrating. A few years ago my dad bought a new Toro with 60" deck and seat suspension. Really nice mower. For whatever reason this one doesn't clump at all in wet grass.
Alan
Offline Tom King
    • HistoricHousePreservation
« Reply #6 on: September 11, 2021, 04:02:29 PM »
This one does, but I have to keep the motor revved up, and go slower than usual.  I can go faster if I wait an hour for the morning dew to leave.
I added a marine lifting eye to the front, to make easy access to the blades.  The stainless
 eye has a 3/4" bolt, and will lift 5500 pounds. I like sharp blades.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #7 on: September 11, 2021, 06:48:52 PM »
I have a Kubota Zero turn, diesel, for 19 years.  It doesn't care if the grass it wet or dry.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Offline scsmith42
    • Whispering Pines Farm
« Reply #8 on: September 11, 2021, 07:05:12 PM »
My 61 Scag Turf Tiger does fairly well in wet grass. 29hp Kawasaki gasser.
Tom's 3638D Baker band mill
Offline gspren
« Reply #9 on: September 11, 2021, 08:35:10 PM »
It sounds like the better ZTs can handle what I want, I'm not picky and it doesn't need to look perfect but my JD garden tractor loads up under the deck and then rattles and drops soggy clumps that need to be picked up if the grass has any dew on it. This summer the heat and humidity was bad and mowing in the afternoon was rough on me, I tried mowing in the evenings with the headlights on but again the dew set in and it wouldn't mow right.
Offline btulloh
« Reply #10 on: September 11, 2021, 09:33:25 PM »
My toro 54 ztr handles wet grass ok without building up or clogging. It needs to be hosed out after Im done, but it doesnt accumulate enough during mowing to interfere with the job. Its not one of the pro models, its just the 54 timecutter. I do recommend getting a higher end toro (or your choice of brands) though.  This one was sort of an emergency stop-gap purchase.
Sharp blades are really important when cutting wet grass.
HM126
« Reply #11 on: September 11, 2021, 10:01:07 PM »
I had even thought about this topic but reading these replies its interesting because we have about 5 acres of yard and will mow first thing in the morning while the dew is on the grass in the summer or after a light rain to keep the dust down.
YellowHammerisms:
Offline mike_belben
  • Pulp Friction
« Reply #12 on: September 11, 2021, 10:57:47 PM »
i only mow when its wet.
Isaiah 63:10
Offline Spike60
« Reply #13 on: September 12, 2021, 07:36:13 AM »
The JD 48" stamped deck has poor airflow and doesn't discharge well. Very similar to the Husky stamped 48". Neither deck does well in anything but ideal conditions. Exmark probably does have the best quality cut in most applications, and the patented baffles are partly why. (I also sell Husky and Ariens/Gravely and they do not perform like the Exmarks)
But any deep commercial deck with good airflow should be able to give decent results in wet grass. Pro cutters start early; they can't wait til lunch time to start mowing. But this is a strange year conditions wise. The weather is giving us Spring like mowing conditions here into mid Sept. One of the problems with this is that when we reach this time of year, we aren't mowing the same "grass" as in the Spring. Unless you have a well treated lawn, the % of weeds and crab grass is much higher than it was 4-5 months ago. Also this time of year, there is a lot more dew on the lawns most mornings, and it takes longer for the sun to burn it off.
My front lawn is nice rurf, and I can mow in any weather; in dry weather the deck is barely damp. The back lawn is filled with weeds and crab grass this time of year. It's more like mowing a salad than a lawn and the stuff just gets turns to slop. Builds up under the deck until it pukes.
Some of the pro guys run different blades during the season as conditions change. They'll switch to gator blades, medium lift, notched vs solid air foil. But it's always a moving target. Last month's solution might be this month's problem. The balance they are looking for is enough lift to get a clean cut, but not too much that it will tend to pack the deck. One guy who is real particular ran gators a month ago and though it was magic how it solved his problems. But now that we're in Fall conditions, he had to go back to the hi lift blades and deal with some deck packing.
One thing i will brag about Exmark, is that at least down through the Radius models, you are still getting a quality Exmatk deck not very different than the more expensive Lazer models. It costs 30% more to make an Exmark deck vs a Toro deck coming out of the same building. Most mower brands really de-content the decks as you drop down the price ladder until you end up with a lawn tractor deck under a Z that travels faster than the tractor speeds that the deck was designed for. Then it's either keep mowing or start raking. :)
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
« Reply #14 on: September 12, 2021, 07:51:03 AM »
Ours is a commercial grade mower because our dealer knows us, knows we are hard on equipment, and sold us the best with a diesel motor.  As Spike60 says, the commercial guys mow all day, every day.  After a couple years, when I came in to get new sharp blades, the dealer laughed and said most of the pros come in buying blades every year, because they wear them down to the nubs.   :o
We have had a series of other mowers, all the way back to a Sears Craftsman riding mower long ago.  However, with the Kubota commercial series, we bought it almost 2 decades ago, and it has been bulletproof.  I don't think it will ever die.  So in the words of Forrrest Gump - "One less thing to worry about."
I would think any brand's "commercial" series would be more than worth the money in the long run.
YellowHammerisms:
Offline Tom King
« Reply #15 on: September 12, 2021, 08:41:03 AM »
Commercial mowers have geared up, very high tip speed blades, and typically good horsepower.  The higher tip speed will sling any grass, even wet, better.
The one I posted a picture of is 72", with 35hp.  It doesn't care if the grass is wet, but if it's also tall, I have to slow down to sling that width, with that horsepower.  If I'm only cutting off a few inches, it doesn't tax it, at all.
The main reason I don't like to cut the grass when it's wet is that the front tires sling water all up in the air.  Commercial mowers also go faster.  I cut the smooth areas as fast as that mower will go, which is 14 mph.  I guess I could fab some fenders, but I usually have other stuff I can do then, anyway.
Offline Larry
    • Copas Sawmill
« Reply #16 on: September 12, 2021, 09:14:28 AM »
I always try to mow when the grass is wet eliminate dust.  First zt was a Husky and now a Kubota.  Both threw clumpy grass until I modified the factory grass chute.  I fabricated a steel plate to replace the chute.  With the metal plate wide open no problems with either mower.
This is similar to what I made.
Advanced Chute System
Their are other's and they are simple to make if you have a few tools.
Offline thecfarm
« Reply #17 on: September 12, 2021, 10:27:37 AM »
WOW!! 14 mph would throw the wife off the mower. The old field is some rough now, that is what we mow. Well we have a lawn, but that extends out into the rough field.
Offline Tom King
« Reply #18 on: September 12, 2021, 12:29:48 PM »
I'm working on getting more of it smooth enough to be able to
 go faster.  The machine has an air ride seat, and power steering, but still have to slow down for rough ground.
Offline gspren
« Reply #19 on: September 12, 2021, 08:20:42 PM »
@Spike60 Do the pro guys usually run their mowers till they're shot or trade in with some good life left? I tend to like pro stuff like the 044 and 261 Stihl saws I use for personal firewood and would like a pro series mower but I know I won't put many hours a year on one. I don't mind used if it gets me a better mower and I won't put much over 100 hrs a year on if that.
Mowing
Started by Darrel on General Board
Last post March 14, 2015, 09:32:28 PM
by Darrel
mowing around walnuts
Started by OneWithWood on Ask The Forester
Last post October 15, 2003, 10:43:40 AM
by OneWithWood
mowing the lawn.
Started by thecfarm on The Outdoor Board
Last post May 26, 2017, 11:59:43 AM
by sawguy21
Forestry Mowing!
Started by QwikDraw on Forestry and Logging
Last post April 03, 2017, 10:57:49 PM
by QwikDraw
