Searching for tips to remove Timber Harvester drive wheel
Started by T4R11, May 14, 2022, 04:30:40 PM
T4R11
I have a Timber Harvester 36HT25 and have removed the 3 bolts holding the drive wheel on the shaft but the flange with the square key is not moving at all. Any advice on how to to get the flange and wheel off?
ladylake
 If thats a taper lock hub  which it sounds like,  screw bolts into the threaded holes until  they push the wheel off the hub, then the hub should come off easy.  Steve
kelLOGg
My cooks mill is like the TH and what steve said is right.
T4R11
