The new low sulfer fuel (on and off road 15ppm) is good for air quality, but has you noticed how fast it burns?( a hole in your wallet).
you all are right it burns faster ,does not lubricate fuel pump and injectors as well ,cost more ,trans fluid does help ,i use power service also ,sometimes i kind of wonder about e p a
Post opinions pleaseI have a 2007 Kubota and a 2008 cat 51 on my woodmizer.Is low sulphur an issue with these engines?If so, how much percentage tranny fluid should I add.Also I had a romance with diesel cars, one '79 Olds Cutlass, smaller of the two engines offered with a 5 speed manual tranny , one 81 VW Rabbit and a 85 Chevy 6.2 pickup in the 80s when diesel was cheaper than gas.Gave up on buying diesels in '88 when it was no longer cost effective. Did keep the Olds until 93 when I sold it to my brother. this was my favorite car of all time.Thanks Pete
Started by Lenny_M on General Board
Started by Autocar on Forestry and Logging
Started by Bruno of NH on Sawmills and Milling
Started by Hayseed on Urban and Community Forestry
