a little
Started by coxy, August 17, 2016, 12:15:06 PM
coxy
brain teaser  my wood shed is 24x22  10ft hi on one end and 12 on the other my owb sits all most in the middle there is only 1 row behind it   my new wood shed is the same 24x22 but the owb is on the corner on one side will I be able to put more wood in there
Ox
In my mind it should be exactly the same wood storage space.
cliffreaves
It has the same volume, but it will potentially make a difference in what size boards can fit where.  To me the new setup will be much easier to figure out, but essentially same.
