Side supports
Started by D6c, July 24, 2018, 03:21:03 PM
D6c
Question for someone with a newer Woodmizer mill that has the pivoting type side supports.
How thick, wide, and tall are the supports?
My old LT40 has the side supports made of 2 x 2 tubing and after adding hydraulics to the mill they are kind of a weak point.
The adjustable mounts aren't beefy enough and won't hold adjustment with the pressure put on them by the hyd. clamp. and I may have put a little bend in the 2 x 2 tubing as well.
Thinking of rebuilding the arms and mounts to make them a little stronger.
The newer WM arms have two rollers at the top.  I see pics of some mills running without the rollers.
What's the consensus?....should I put the rollers on or not?
Brad_bb
If you mean the uprights/backstops, the ones on my 2014 LT15go are 9 inches from the bed (top of crossbars) to the tip.  I was milling today and coming close to them.  If I set my head at 9 1/8" I was ok.  FYI I do not have the bearings on the end of the support.  I want to get them though.
Chuck White
With the sawhead set at 11¼ inches, my blade will "just" clear the rollers by about 1/8 inch!
I'm not positive, but I think that the log-stops at ¾ of an inch thick!
