Leave your wood to dry in the wall?
Started by Satamax, October 17, 2021, 04:15:14 AM
Satamax
Hi everybody.
I have cut this lately. It is punky larch.
I am afraid that it is not even worth drying. i was wondering, could i make 2x6 with the good (ish)  edges, fix that against an hollow brick wall, fit insulation in between, cover with fermacell, and leave it to dry in the wall? The good edges are nearly 6 inch including some sapwood. It is not structural, just a spacer for the insulation. My house is very dry, rarely more than 30%rh. What i'm afraid of, is dry rot. What do you think guys?  It shouldn't do anything with the house being dry.
jimbarry
If a short piece can be broken in half with just your hands, I'd say it's not worth the effort to dry further. Depends though on your intention of useage. I cut material like that in 3/8" thick for scrollsaw projects. If it is unstable, a epoxy type material like a rotted wood restorer or wood hardener can help.
Satamax
Thanks a lot Jimbarry.
Chainsaw and test in order then.
