Lost my Contacts
Started by Raider Bill, September 20, 2010, 10:37:09 AM
Raider Bill
yesterday I upgraded to outlook 2007 from outlook 2003.
Now all my contacts are gone.
Any Idea where I can go to find them?
The First 70 years of childhood is always the hardest.
Warbird
Seems you aren't the only one to have experienced this problem.  I do not use Outlook but here is one possible solution:
http://thedailyreviewer.com/outlook/view/outlook-2003-contacts-list-disappeared-after-upgrade-to-2007-103140032
Raider Bill
Crap. I did this but don't see where to delete exchange as it doesn't list it.
Warbird
Jeff, do you use Outlook?  I don't have it available to run and give pointer on.
No I don't, in fact I detest the program.  I have some web clients that use it and it is constantly the source of some sort of malfunction or headache.
Raider Bill
Bill can you revert to the earlier edition? If so, are your contacts there?  If so, can you export them to an LDIF file?  If so, you may be able to then upgrade, and import the LDIF file to your upgraded program.
I use Thunderbird by Mozilla
Raider Bill
How do you revert to the older version?
I Don't know other then if there is an option in uninstall like there used to be with internet explorer. I dont use that either. ;)
Do you have the original install disc for the older version?
Raider Bill
I have 2003 stored on my d drive
Texas Ranger
Quote from: Raider Bill on September 20, 2010, 11:50:34 AM
Can you run it from there? if so you may be able to export the address book
Warbird
Or pull out the address book (contacts) file from the D drive, then import them to the 2007 installation?
I also detest Outlook.  If you like using a hard client, I recommend Thunderbird.  Otherwise, most providers supply web mail clients.
DouginUtah
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
Raider Bill
I guess I mis spoke. outlook 03 installation folders are on my d drive. C was where it was running from.
I found the pst folders under documents and settings.
I am now attempting to download and install thunderbird to see if that will pick them up.
Dang it, 03 wasn't giving me any trouble just figured to upgrade now this mess.
Edit.... downloaded thunderbird but it did not bring any of the lost addresses over either.
DouginUtah
Bill,
Did you go to Tools | Import ?
-Doug
Raider Bill
Tried import, export all the ports...................
Now it looks like outlook corrupted my contact file as even thunderbird won't accept it.
I have a guy coming over tonight.
Hope whatever he does works as there are about 1600 names there.
Jeesch
