Flagging tape color
Started by livemusic, May 05, 2024, 11:54:41 AM
livemusic
If your tract is to be logged, are you supposed to mark the 'take' trees or the 'leave' trees? Is there a certain color or does it vary a lot?
Do you favor using flagging or paint and what is most common? If paint, how do you mark it and do you just use a brush or what? TIA!
Bill
mudfarmer
Around here flagging would mostly be used for marking out the landing and trails, riparian boundaries, sometimes harvest boundaries etc.
Your contract should spell out whether it is leave trees or harvest trees that are marked. "Trees to be harvested are marked with [color] paint. All marked trees must be felled." or "Trees not included in harvest are marked with [color] paint. These are not included in sale and are not to be harvested. All non marked trees are included in sale" etc etc and similar.
Wildlife trees are often marked with a W in whatever color and are not to be harvested. Bump trees on skid trails sometimes marked with a B and are to be removed after the portion of the sale beyond is harvested completely.
I'm sure there is lots of regional variation like with everything else and am curious what those might be.
© Skid-Er-Dun Slogging, a Delaware Limited Liability Corporation
Our harvest trees are marked with a paint swath at breast height and another on the stump/roots.  The color will be designated on the contract.
Wildlife trees are flagged with ribbon around the perimeter.
Otis1
I mostly use flagging for a temporary boundary layout before I paint it. You would use a lot of ribbon and be time consuming if you tied around every cut tree. Generally speaking, you want to mark whichever(cut tree or leave tree) is going to be the least amount of trees so less work. Also depends on if you want to look at reserve tree paint for however many years. Always marked on at least two sides above DBH and a stump mark all the way to the ground preferably kicking the moss off. Stump mark is an accountability method, so that after trees are cut you can still make sure that loggers are only cutting marked trees.
Around here, the USFS uses orange paint for boundary between cutting units, red for private boundaries/ surveying, and blue for cut tree marking. Our state DNR does it the other way and uses blue for boundaries, orange for cut trees, and green if marking reserve trees. I have seen some purple paint for private boundaries. I prefer marking cut trees with blue paint, it is brighter and easier for color blind people people to see. As far as wildlife trees, if I'm cut tree marking, then I just don't mark that tree. If I am reserve tree marking then I will paint it with whatever the reserve color is.
I think the most used brand is Nelson paint. As far as application, it is usually a spray gun. Either a handheld unit with a quart of paint that you have to squeeze a trigger/pump or something backpack style that will hold a gallon and is pressurized. I use a Panama gun, it can be pressurized like a car tire. I've seen people use one of those backpack pesticide sprayers but I think you have to get the right nozzle.
According to the side of a Nelson paint box, foresters used to put a rock in a sock and dip it in a gallon of paint and swing away.
If you search for forestry supplies you will find everything you need.
I'm currently marking 8-10 acres/ day in hardwoods, then Ill be doing some red pine plantations. On track to do over 1,000 acres this summer by myself.
livemusic
If harvest trees are marked, everything else is not harvested. So, why would you mark a wildlife tree? Only thing I can think of is it's marked to draw attention and imply "don't knock this tree down!" Assuming that 'wildlife tree' means a dead snag or hollow tree, etc.
Is there any common color used for 'leave it' or 'take it?' -- edit... oops... I see that this was addressed above as I was posting.
Bill
Correct, do not damage the tree in any way.
Rhodemont
I have a harvest in progress.  My Forester used blue paint in a spray pack on his back to mark those trees to be harvested.  Firewood trees got a blue dot about head high.  Timber trees/logs on the tally sheet got a blue  diagonal slash at head height with a dot at the base.  the dot at the base below the cut verifies the tree was to be harvested.  The perimeter of of the cutting doubles up on the dot or slash indicating take this tree but that is as far as you go. A couple 2 acre areas being patch cut to promote oak regeneration are outlined with a vertical slash meaning do not take, this is as far as the patch goes. Those healthy oaks left in the patch to provide mast for regrowth are Marked with a "L" meaning leave do not cut.  After the harvest we (me, Forester, Logger) will walk the acreage and verify all blue dot firewood, blue slash timber (stump with dot) have been taken.  I will get paid by the cordage load of firewood that gets loaded and my percentage of the sawmill tally sheet for logs.  It is all very clearly written in the contract my forester prepared and my logger previewed with some comments before signing.
All the firewood dot trees were cut and stacked this past winter.  No cutting can be done April 15 - Aug 15 because of wildlife (bird and bat) nesting seasons.  In august the logger will start cutting the timber trees and bring in his forwarder to haul out the timber logs and firewood.  A tally will be kept of his firewood truck loads of 7 cord each and I get a copy of the tally sheets from the sawmill.  These will define what $ are coming to me.
I already have a registered forest plan prepared by my Forester.  The Cost for him to mark the trees and prepare contract for the 42 acres was $1500.  I highly suggest anyone getting logging done get a forester who you get along with and agree with his line of thought.  Then let him do what he doe professionally....makes it all so much easier!
Ok: to answer your question, blue paint.
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
Old Greenhorn
I am not involved in this directly either as a forester, cutter, or landowner however, around here if I see a tree with a painted blue band I KNOW it is destined for cutting. Very common. But it's a regional practice I think. I see orange flagged trees, mostly done by landowners to indicate trees they wanted quoted for removal. Homeowners use any old color flagging. Surveyors here use pink for corner markings and sometimes orange for property lines, if they are doing a long string.
 When I started flagging mushroom trees I started with green, but that was hard to find later, especially after leaf out. SO I switched to blue, also hard to see and it might confuse others as to what and why that tree was marked. I finally settled in on a blue/white striped flagging as my 'own' and been using that for a few years. Everybody sees those and knows, or could easily find out, they are 'my' trees. It's unique, and that's what I needed. I gave a couple of rolls to the landowner to keep in his buggies so he can mark trees when he finds them.
 One thing I learned, if you flag trees rather than paint, you have to tie them fairly loose or go around twice. I have some trees out there flagged 3 years and the tree grows and bursts the tape. I've gotten to the point that I put a bow in them and re-use the flagging on other trees because I have gone through quite a few rolls. ffcheesy It's not a buck a roll anymore. :veryangry: Also, if I have my left jacket pocket stuffed with used flagging I know I should be thinking about marking more trees.
 I know that doesn't help you a bit, sorry. But it's Sunday night and a bit slow here, so I thought I would just throw it in.
Ron Scott
Tree marking paint is a specialty paint used for long lasting on tree bark and comes in a variety of colors which are used for laying out the timber harvest area and designation of the trees to be cut or not cut. Different paint colors and letter codes such as WL for wildlife trees to be left uncut and undamaged are used by the foresters preparing the timber sale. R may be used for reserved trees for whatever the reason spelled out in the harvest contract.
Whatever the colors and codes painted on the trees, they should be spelled out well in the timber harvest contract and shown on the timber sale area map to be followed as designation codes for the logger and their cutters to follow and perform the harvest accordingly.
Marking codes and paint colors are usually common in meaning among the various governmental agencies, consulting, and timber company foresters who lay out the harvest areas and the loggers and their cutters soon learn the colors, designations, and codes and perform the harvest accordingly.
~Ron
Machinebuilder
In many places purple paint is used for no trespassing.
I have looked it up for Tennessee. there has to be a No Trespassing sign with contact information at the main access point.
Then the boundary can be marked with purple paint marks, I think there is a size and distance to be followed.
I don't know about marking timber.
Dave, Woodmizer LT15, Husqvarna 460 and Stihl 180, Bobcat 751, David Brown 770, New Holland TN60A
petefrom bearswamp
IMO you, use Ron's post
He has a world of experience and a wealth of knowledge
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
PJS
Curious how you guys that mark trees are watching and determining for a wildlife tree?
Been cutting trees, mostly spruce/balsam/pine, but I don't like killing wild critters if I don't have too. I can go past a tree and come back for it later. Other then using a pair of binoculars, any tips or tricks about what one can watch for?
Ron Scott
Wildlife trees are live or dead trees designated for wildlife habitat or retained to become future wildlife habitat.
They are usually over mature trees with obvious dens, nests, and cavities already existing and being actively used by a wildlife game or non-game species or they are tree species that are mast producing and providing a wildlife berry or nut food source such as the oaks, cherries, American beech, ash, hickories, apple, non-timber shrub and berry species etc.
The longer living hardwoods are favored for retention of cavities and dens over the short-lived trees such as the aspens, birches, etc. 1 to 5 such trees are usually designated per acre and marked with a painted "W" or "WL" to be retained and not damaged or fallen in the timber operation. A fine may be assessed the logger as spelled out in the timber harvest contract if they fall or damage the designated wildlife trees in any way.
~Ron
Willsterman
What prevents the bad apple loggers from using a can of their own marking paint to mark trees during harvest in a mark for cutting contract?
A friend installs a game cam to count the number of trucks hauling out.  Has anyone used a scale stick to scale a few logs in the pile while the logger is nearby to give the impression the logging is being "audited?"
Any other methods to keep a logger honest?
I once asked 3 loggers about their recommendation to thin a 40 acre red pine plantation.  One logger said take every other row, another said take every third, and another said to take every 5th row.  That also indicates to me that having a professional you hire to represent your own best interests make sense.
Here the Forester is working for the landowner and he makes periodical checks during the logging operation.  He knows the cruise and what is being harvested.  He also knows the buyer and logger quite well.
If there was any underhanded activity, that buyer/logger would be blacklisted not only from his bidding but also from the other Forester's bidding opportunities.
mudfarmer
Willsterman,
Crooks are gonna crook no matter the profession. All you can do is cover bases. Hire a reputable Forester, have a solid contract, hire a reputable logger.
The hiring part may be hard for most land owners-- it is not like most are part of the forest product industry! And may only harvest once. Not a lot of room for error. Here again, cover your bases the best you can and make sure your karma is up to snuff.
A brief story: I know two land owners,  neighbors of each other. One had a lot of harvesting done and no issues whatsoever. So the neighbor hears that and hires on the logger. The second guy had a lot of harvesting done too but never received a dime from the logger. The contract was so weak it basically didn't exist. So references only help so much if you are dealing with a crook to begin with.
Another story. A guy hires a Forester and has a good contract. The Forester markets the wood anyway so he suggests a logger he knows. The land owner asks to see a couple jobs, only gets to see one and it is real nice work. He finds out after his job starts that the logger showed his own property and thinks he got taken for a ride. There are small issues throughout that are dealt with amicably because they are addressed in the contract. I asked if he would use the Forester or logger for work again and he said yes it all worked out very well and now you cannot tell the logger was ever there.
-Management plan
-Contract
-Someone that knows what they are doing looking out for you
Old Greenhorn
I can't imagine a logger that would do that and risk their business and reputation. It's a small world and word gets around quick. I would view that as akin to cattle rustling or horse theft in the old west (or today). The solution used to be swift, but these days can take longer but either way, it's not a 'tolerable thing.'
Around here, that logger would be done.
We don't have a LOT of logging operations around here, maybe 4 to 6 operations. I never hear of anything like that. But we have a lot of competitive land clearing, site prep type guys, especially with the migration of city folks building new places. I fairly often hear of one or two of these guys getting thrown off sites mid-job because they were not following the contract specs, and another has to step in and fix things. In fact I have seen it happen to one company 3 times in the last year alone. They just keep finding clients that are new to the area.
My friend Bill regularly gets jobs to go in quick and fix after one of these companies gets booted. (Almost always, they were jobs he already bid and didn't win, because his price was too high.)
I can see this happening in logging also, there are always crooks out there in every business, but the world is so small, nobody could last long with a reputation like that.
barbender
 Willsterman, the 3 different loggers were just using 3 different methods, probably due to having different types of equipment.
 I'm not sure about the every other row guy, but a 3rd row thin is typical of thinning with a feller bunchern especially a rubber tire buncher. You cut the one row, and can reach into one row on each side.
 A 5th row thin is typical with cut to length equipment. You take a row, and can reach over 2 rows on each side with the harvester.
Ron Scott
"Always, Always" have a Timber Harvest Contract and a performance bond spelling out the terms and performance conditions of the timber sale. Terms and conditions will vary depending upon whether it is a Scaled Sale where the timber is paid for by scale in the woods or at the mill or a Lump Sum Sale where the timber is paid for before cutting the standing trees.
The harvest area needs to be inspected regularly by the administering forester for compliance. Most responsible loggers will do a good job and will not risk their reputation on doing poor work and cheating the landowner. The "bad apples" are usually weeded out soon and out of business.
Getting the stump mark low on the tree is very important for identity of the trees authorized for cutting. Where a logger is suspected of marking other and additional trees with their own paint, especially in very high value timber, there is a special tracer paint that can be used under special controls.
It is always best to have the timber sale laid out, prepared, and administered by a professional forester working for you. Loggers have a lot of knowledge to get the job done, but they are not foresters. 😉
~Ron
Ron Scott
The row thinning configuration for thinning a red pine plantation is usually determined by the basal area of the stand as well as the logging equipment commonly being used in the area. A leave basal area of 90-120 sq. ft. is common in the Lake States; a leave BA 0f 120 for stands being nurtured for utility poles.
~Ron
barbender
 Many agencies in my area also used to go with that basal area as well, Ron, and for the same reason- managing for poles. I heard one forester they were moving away from that, because historically there has only been one pole buyer up here to deal with. And they're not always easy to deal with. This forester said they were coming to the conclusion that it is better for them to manage for maximum growth rather than poles, so they are starting to thin more aggressively.
 That higher grade wood doesn't pay any more if the pole buyer doesn't buy it. The stud and pulp mills aren't paying more for it.
livemusic
Flagging tape... bought another role of white, which I use to mark my dogwoods so I can readily see them and not crash into them if I fell another tree for whatever reason. I prefer 150ft rolls because they more easily fit into my pants pocket than a 300ft roll but 300ft is all the supply house had. And wouldn't you know it... I left that big roll to where it was exposed overnight and it rained and got soaked, and the inside spool pretty much turned to mush, it's made of a cardboard type product. It sure screwed up my roll! This is a rare time that I say I wish the spool was made of plastic!
Bill
TreefarmerNN
Quote from: Old Greenhorn on May 13, 2024, 08:41:27 PMI can't imagine a logger that would do that and risk their business and reputation. It's a small world and word gets around quick. I would view that as akin to cattle rustling or horse theft in the old west (or today). The solution used to be swift, but these days can take longer but either way, it's not a 'tolerable thing.'
A good forester is worth their fee, although some of them have an inflated view of their worth. . .
I've used several foresters.  One was more responsive to the buyers than to me and let stuff go during the harvest that should have been stopped.  I quit using him.  My current one helped mark trees to leave and then found the logger was cutting them.  The buyer offered a nonsense offer for the trees which I refused as the law in Virginia is triple damages for trees cut without permission.  The forester helped estimate the value of the cut trees.  He's done several sales for me and helped evaluate some stands which I ultimately haven't sold.
Loggers can get away with a lot since most people sell only a few times during their lifetime.  I will walk a logging site to check for issues but the sales contracts have a provision that says the forester can stop the harvest if problems occur.  Buyers don't want the landowner to have that ability because most landowners are as picky as I am and would stop a harvest when there's really not a problem.  If the forester has a good reputation as a straight up guy (or gal), the reputable loggers don't mind that being in the contract.  Shady ones either low ball bid or don't bid at all.
doc henderson
I think the hanging law is still on the books in Ks and Ne for horse theft.  cattle rustling is also considered very serious, as it is a way of life for many.
Before the Forester marked any trees on my property before the last timber sale, I personally went through and red flagged any trees that I did not want harvested.  This worked very well and as a result none of my targeted trees were painted for harvest.  It's simply a matter of communication.
