need 172 ford gas engine in Maine
Started by stihlsaw066, January 13, 2013, 08:03:12 PM
stihlsaw066
Hello, I have an old 62
   timberjack 200,the motor is tired and im looking for a good runner in the new england area, Anyone know where I may find one ? I also have original manuals for the skidder too,I can make copys if anyone needs them but its not cheap.
mad murdock
Why not rebuild it? I bought new parts for my 172 ford diesel from Glemco tractor parts in MO, a cyl/piston kit with rings and all the gaskets I needed was around $550.00.  Gasser parts prolly are less $$.
coxy
nice looking older skidder love to see them still working
mad murdock
North River Energy
NB: I have no affiliation with the seller.
Ford Tractor 172 Gas Engine - $1500 (Milford, NH)
Date: 2012-12-02, 1:17PM EST
Reply to this post qczmn-3408059822@sale.craigslist.org[?]
I am selling this Ford tractor gas engine. This engine is complete, running, good oil pressure and no engine noises.Asking $1500.00. If interested and need more info. please email me. Thanks....
it's NOT ok to contact this poster with services or other commercial interests
PostingID:3408059822
WH_Conley
I think I would second the rebuild idea, unless I had a bad block.
Bill
lumberjack48
I worked for a guy up at International Falls, back in 1965 that had one just like it, nice skidder.
I bought a new C4 TF in 1968 with the 172 Ford gas engine.
I had a 1966 Bronco, it had a 170, 6 cylinder, heavy duty motor, 105 hp, mechanical lifters, 2 oil pumps, 8 gt oil pan and a carb that wouldn't flood out going up or down hill.
I always thought this would work good in a skidder.
loggah
You might be able to find one in a old generator, welder, set or air compressor,i have seen them in both. Don
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
John Woodworth
As to the tractor motor, will not interchange, different from the industrial, cheaper to rebuild than find a used runner if you can find one, however if you bore for new pistons don't go over .30 or it will overheat, they can be bored to .60 but that is never done.
If the bore is already excessive the block can be over bored and sleeved back to standard but by the looks of the machine I doubt you will have that problem.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
