Author Topic: mod eliminates parallax error  (Read 2474 times)
Offline burlybee
  • hobbyist
« on: August 15, 2020, 02:49:13 AM »
I just completed a mod on my Linn Lumber 1900 that eliminates parallax error.  I mounted a line laser to draw the level directly on the measure.  It is so much easier to read!  No more bending to get to the same level.
When you are retired, every day is Saturday.
Offline stanwelch
Re: mod eliminates parallax error
« Reply #1 on: August 15, 2020, 04:34:15 AM »
Sweet. I like it.  What are the specs and source for the laser?
Woodworker, Woodmizer LT15, Stihl 026, MS261CM and 460 chainsaws, John Deere 5410 Tractor 540 Loader,Forks & Grapple, Econoline 6 ton tilt bed trailer
Online Old Greenhorn
    • Woodsman Forest Products
« Reply #2 on: August 15, 2020, 05:33:14 AM »
I love it! Can you give us the details? Specs/source for the laser, power requirements, etc? I have a manual mill so I would have to add a battery, but that is sweet and very worth it! I see you chose red, do you have any problems seeing that in direct sunlight?
Oscar 328 Band Mill, Husky 450, 562, & 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, but almost.
Offline Nebraska
« Reply #3 on: August 15, 2020, 09:52:25 AM »
 popcorn_smiley agreed, like the addition.
Offline barbender
« Reply #4 on: August 15, 2020, 11:05:35 AM »
That would definitely help with not only parallax, but also my late night sawing😁
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
« Reply #5 on: August 15, 2020, 12:25:32 PM »
Nice Job.
Online trimguy
« Reply #6 on: August 15, 2020, 12:44:01 PM »
I like it.
Offline Banjo picker
« Reply #7 on: August 15, 2020, 01:04:50 PM »
I use several different scales at different times.  They are magnetic 🧲...guess I could just move it.  My sight pin is basically right at my eye level so thats not much of a problem, but with the 3 eye surgerys I had on my right eye I am sure it would be beneficial.  So I too wait on your source.  Tim
Offline KenMac
  • I'm not as new as I was. but often feel very old!
    • ItGrowsOnTreesWoodworks.com
« Reply #8 on: August 15, 2020, 03:38:46 PM »
Likewise, I'm interested as well. I use the setworks as much as is reasonable, but a crisper and smaller line on the scale would definitely help.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Offline never finished
« Reply #9 on: August 15, 2020, 04:49:38 PM »
 I have to have one
Offline burlybee
  • hobbyist
« Reply #10 on: August 15, 2020, 07:26:56 PM »
Just a quick update now.  More later.
The laser module is red because I was prototyping and wanted a cheap test unit.  It was under $5 as I recall.  I wanted a short focal length 60 degree spread module.  When this unit fails I will probably replace it with a better unit.  Because the throw distance is so short (about 3 inches), the laser does not need to be very powerful.
I made the L-brace to hold the laser out a few inches from the measure.  The laser diode unit is mounted in a heat sink which transfers heat to the L-brace as well.  The mount is a farhop 12mm industrial aluminum laser diode module mount.  It cost about $11.
My mill is a Linn Lumber 1900 with power up/down and feed.  I pulled power inside the controller box from the deep cycle battery after the on/off switch.  That way the laser comes on when I turn on power for movement.  That voltage is 12VDC so I put a 5V regulator inside the box.  The laser module runs on 3-5VDC.  It would be very simple to just power it from two AA batteries.
Because the laser is mounted 90 degrees from the measure it will be easy to change magnetic tapes without parallax shift due to thickness changes.  It is important not to shine the laser in my eyes.  On my mill the laser spill-over from the measure bar falls on the back of my bandsaw frame.  I think it would be the same for other mills, but I can't say for sure.  DO NOT get a high power laser module and let it shoot you in the eyes.
Offline burlybee
  • hobbyist
« Reply #11 on: August 15, 2020, 07:37:11 PM »
I will try to post a parts list and building instructions tonight.  It isn't very complicated or very expensive.  The L-brace is the only part I had to make, and someone else may have a good source for a prettier unit than the one I made.  Mine is just 4" aluminum bar bent in a vice.  The downside of aluminum is if you want to tack weld it to your mill.  I plan to mount mine with screws because I am the only one on this forum who doesn't weld.  Right now it holds quite fast with command strips.  While I don't weld, I make very pretty wire harnesses.  If the wires don't hold, the light goes out.  You will have to work that out for yourselves.
« Reply #12 on: August 15, 2020, 07:54:18 PM »
Take your time. You are not the only one here who does not weld. ;D and I think welding in this case is not the best choice anyway. We really want to know where you got that little laser and mount I think mostly. I'd rather have a 12V laser to work on a simple gel cell. I don't have electrics on my manual mill.
Offline ljohnsaw
« Reply #13 on: August 15, 2020, 08:13:53 PM »
 :P
I, too, would want 12v but a regulator will work.  Always an issue on mine as the scale if fixed and the "line" moves up and down.  So sometimes I'm squatting (for that last 1" board) and sometime I climb up on the rail when doing the first few cuts on a monster log.
SkyTrak 9038, Ford 545D FEL, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 42" capacity/32" cut Bandmill up to 54' long - using it all to build a timber frame cabin.
Offline burlybee
  • hobbyist
« Reply #14 on: August 16, 2020, 02:30:41 AM »
Here is a list of the parts I used for this project.  Be aware that I plan to switch out the laser diode module in the future for an industrial model.  The reason for this is that the cheap laser diode module I bought is not rated for continuous use.  It may never wear out, but when it does it will most likely die of heat.  An industrial module does a better job of dissipating heat to the heat sink.
1 - the laser module is a 12mm adjustable focus line laser module.  I bought a bag of three for $8.49.  Be sure to get one that can focus at 2 to 3" because you are going to place it close to the focal plane.  Here is a link to the module I bought Amazon.com: HiLetgo 3pcs 650nm 5mw Laser Head Laser Tube Adjustable Focus 3~5V Red Laser Tube for Sight Positioning Sighting Telescope(Dot/Horizontal Line/Cross Optional) (Horizontal Line): Computers & Accessories
2 - the heat sync is also the mount for the laser module.  Again I bought a 12mm unit to match the laser module.  It is a farhop 12mm industrial aluminum laser diode module mount holder.  It cost me $10.89 on Amazon.  Here is a link to the unit I purchased farhop 12mm Industrial Aluminum Laser Diode Module Mount Holder with Hex Wrench - - Amazon.com
3 - my laser module operates on 3-5VDC and I wanted to run it from a 12VDC battery.  I bought a package of 10 2 amp voltage regulators for $5.90 on Amazon.  These convert the 12VDC  to  5VDC for the laser module.  I used an L78S05CV.  Here is a link to the modules I bought ST Micro L78S05CV Semiconductor, 2 Amp Positive Voltage Regulator, 5 V, 4.6 mm W x 9.15 mm H x 10.4 mm L (Pack of 10): Amazon.com: Industrial & Scientific
4 - I built an L-brace to hold the lens of the laser module out 2 inches from my scale.  The laser needs to be out far enough not to block your vision of the scale.
Once I got the focus set for the thinnest line possible, I put some locktite on the lens threads.  I don't want the lens to turn when the sawmill vibrates.
It would be easy to power the laser from 2 AA batteries with something like this Amazon.com: LAMPVPATH 5Pcs 2 AA Battery Holder with Switch, 2X 1.5V AA Battery Holder Case with Wire Leads and ON/Off Switch(5 Pack): Home Audio & Theater
Offline donbj
« Reply #15 on: August 16, 2020, 11:05:55 PM »
That! Is a cool idea!
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #16 on: August 17, 2020, 09:11:13 AM »
This is awesome. I have a fixed scale that measures up from the bed and an aluminum bar for my line. Works well but the laser is pretty sweet. I do need to add a movable bar and still keep the fixed so I can always have my last cut be a normal size.
If I cut all the same board thickness I can just start at the top and work down the scale but if I decide I need a 2" board in the middle of my 1" board that messes all my scales up.
Online chet
« Reply #17 on: August 22, 2020, 08:35:02 PM »
My cheap low tech remedy to eliminate parallax error, a piece of lexan with reference lines on each side.
No double reference lines yer dead on  :)
Offline tawilson
« Reply #18 on: August 22, 2020, 08:42:13 PM »
You also don't have the indicator arrow blocking the number you are on, which is another reason I switched to the laser. Now I'm thinking that lexan setup with an led light and maybe a magnifier over the numbers would solve a few things for me.
2017 LT40HDG35 WIDE
BMS250 and BMT250 sharpener/setter
Woodmaster 725
Online chet
« Reply #19 on: August 22, 2020, 09:04:21 PM »
A more clear pic taken without da camera flash fuzz'n stuff up.
Error 503
Started by 21incher on Technical Support Topics
Last post December 08, 2017, 05:04:55 PM
by Jeff
Peg error, how do I fix?
Started by neckjim on Timber Framing/Log construction
Last post June 20, 2022, 07:25:48 PM
by neckjim
a-1 error
Started by Golfstove on Firewood and Wood Heating
Last post January 21, 2010, 02:37:23 PM
by Golfstove
Error 503
Started by pineywoods on Technical Support Topics
Last post November 24, 2016, 06:10:18 AM
by Peter Drouin
