Skid steers
Started by Redhorseshoe, October 21, 2021, 11:09:38 PM
Check this feature on the John Deere cabs as seen at minute 14:00 of this video.
John Deere R series cab / Beer cooler option - YouTube
Maybe Kubota needs to know that too.
Walnut Beast
customsawyer
I have a Lincoln also. Mine is getting close to 20 years old. I have had to buy new batteries a couple of times but they weren't to bad being the little ones.
www.thecustomsawyer.com
Bruno of NH
I have a Milwaukee 12 volt grease gun
I already have lots of 12 volt tools
I remember you have a dewalt pole saw , the dewalt is good as well.
They are all built much the same .
taylorsmissbeehaven
I had a similar experience at the (now under much better ownership) John Deere in my area. I had just flipped a house and planned to buy a tractor. Had been cutting 4 x 8 sheets of Hardi siding all day for an apartment complex and was covered in dust. Told the salesman I wanted to buy a tractor they had on the lot and a box blade. He looked me up and down and told me it would be more than I could afford. Not another word was said. I drove straight to the New Holland dealership and bought the best purchase I have ever made.
Opportunity is missed by most because it shows up wearing bib overalls and looks like work.
Milwaukee.
Better than sliced bread.
Walnut Beast
This guy is a big mulcher/ tree service guy that has a few of these Skidsteer Ryan hot saw feller bunchers and he loves them.
https://youtu.be/kGtmpQFTw28
Walnut Beast
If he doesn't save anything he probably is going to pick the piles up with a big excavator and feed into a big horizontal grinder.  Another guy I know will take his 735 TimberPros and cut then  feed right into a 1000hp horizontal grinder of the stuff he doesn't save
OH logger
I have the pro lynx track cleats. Wow what a difference they make. I only use them in winter. They really bite even on hard packed slick snow where without em you just spin 👎🏿
john
YellowHammer
I'll have to look at them.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
enwinn
A bit different view of JCB Teleskid 3TS-8T lift capabilities:
Testimonial: JCB Teleskid 3TS-8T - YouTube
customsawyer
I demoed one of those JCB track loaders about 5 years ago. I really liked the side entry and the teleboom but it didn't have any more lift capacity than my New Holland with tires. Maybe they have increased that.
Tom K
I believe JCB's largest track loader has a capacity around 3100 lbs. The teleskid is rated around 3700 lbs which I believe is the same as the Deere 333G
YellowHammer
I also looked real hard at them, and talked to a dealer at length.  They have a lot of good things going for them.  However, lift capacity was an issue and the dealer said the rating was there for a reason.  He did say there was a very good warranty on the boom section, and it was "never a problem."
However, I got one snippet of information that changed my mind, and it was from a guy who recovered one from a rollover.  He said it he felt it was very difficult to right because the massive arm on one side made the whole vehicle heavy to that side.  He said as he was trying to roll it back over, it wanted to re roll to the heavy side.  It was this opinion that the single arm made it "unbalanced" and that eliminated it for me, as I wanted to use it on very steep slopes and so not being perfectly balanced would not be my preference.
This is just conjecture and opinion from the one guy, I have not seen it anywhere else, but it seems to make sense.
I would like to know if JCB's are heavy to one side and if it can be felt by the people who own one?
YellowHammerisms:
Now YH, take it from someone that ran asphalt rollers in a former life- some of the older machines were heavy to one side like that, and you could use it to your advantage. Sometimes you would run the light side oriented one way, so the drums wouldn't leave a mark on that side. You could've had the heavy side of that JBC on the high side on slopes and been sidehilling like nobody's business😁
 I got out of more than one pickle in a forwarder swinging a grapple of wood out to the high side, or opposite to the soft side in swamps. Having 1500 plus pounds extended 25' to the side does wonders for balance😊
YellowHammer
Well, that never occurred to me.  Good tip.
YellowHammerisms:
Or it may have been that all of that weight off to one side, was so high up that it made you unstable either way🤷‍♂️😊
customsawyer
Quote from: Tom K on August 25, 2022, 07:01:12 AM
I don't know about what the JCB is rated for. I have the 333G JD and it will lift twice what the JCB that I demoed would. On another note I think the tipping load for the 333G is 10570 lbs. It won't do that in something like a pallet of lumber. I have a 10,000 pound fork lift that will lift more than the 333G. There is a new one coming out from Case/New Holland that I heard is bigger and stronger. Don't know any details on it though.
enwinn
Actually, I think I like the Mecalac 6MCR even better.
Mecalac 6MCR lifting 2.5t Concrete Tank - YouTube
He gets a bit tippy but that is impressive for a 5,000 pound load. Freaking expensive though!
enwinn
This comparison of the Mecalac 8MCR to the Hitachi ZAXIS 85 USB "standard" excavator gives a good overview of how these MCRs are a bit different.
Mecalac Skid excavator Vs Standard Excavator - YouTube
enwinn
Oh boy. I'm in love. Somebody give me a boat load of money please.  ;D
The custom log trailer in this demo can be adjusted to carry up to 24' long logs.
Mecalac 8MCR Demo - Royal Cornwall Show 2022 - YouTube
Walnut Beast
Yep! It's easy for people to talk trash when they don't really know much about the machine
Walnut Beast
Quote from: enwinn on August 26, 2022, 10:37:32 PM
Cool log trailer! Thanks for posting the recent video!
Walnut Beast
Deere is supposed to put a 120hp in the new 335. And Kubota supposedly. Maybe true br>
Me too, I'll take a boat load too!!!!  :D
