Author Topic: Sawing With My Wife and Not Arguing  (Read 3193 times)
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« on: August 01, 2022, 01:25:52 AM »
I made this video of my wife and I sawing up a few logs.  Iím not sure how many others sawmill with their significant other, but hereís how we do it.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a tree.  Sawmills cut logs, not trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  So donít burn the cookies.
Sawing is fun for the first couple hundred boards.
Online Walnut Beast
Re: Sawing With My Wife and Not Arguing
« Reply #1 on: August 01, 2022, 01:59:25 AM »
Great video! You better take care of your helper with a Hawaii vacation since she is always working hard!!!. Great example of being efficient in every aspect and teamwork! Well done 👍
Offline doc henderson
« Reply #2 on: August 01, 2022, 02:56:49 AM »
my wife will come out and say hi, but then goes back in the house.  Probably for the best.  Nice video.   8)
Offline randy d
« Reply #3 on: August 01, 2022, 06:12:27 AM »
My wife is my partner I saw a log and she is the tail gunner then she will saw the next log and i am the tail gunner.
Online thecfarm
« Reply #4 on: August 01, 2022, 06:37:19 AM »
Yes, you need to know what the other one is doing or going to do.
Good sawing too!!
Offline jpassardi
  • Converting Tree Carcasses 🌲
« Reply #5 on: August 01, 2022, 06:38:38 AM »
Robert,
I caught this on Youtube last night. I got a smile out of the title.
LT15 W/Trailer
Husky 372XP, 550XPG, 60, 50
Kubota RTV 900
Orlan EKO Wood Gasification Boiler
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: August 01, 2022, 07:41:57 AM »
Very nice video.
I agree about the work shirts.  I only wear 100% Cotton T shirts in the Summer.
PatD and I are 50-50 in the sawmilling business.  I makes it and she spends it.  :D  :D
Offline Ed_K
  • Leave it better than you found it. Ed_K
« Reply #7 on: August 01, 2022, 08:32:40 AM »
 Since I got sick Rita has done all the sawing that needed done. She's getting pretty good at it but doesn't like the scale I modded on the mill. She found a better one at Runnings that I'll put on when we move the mill down to the sugar house ( it's closer to the house ).
Ed K
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #8 on: August 01, 2022, 09:14:54 AM »
Does she run the saw too? Or just the bull work?
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #9 on: August 01, 2022, 10:06:52 AM »
   I think mine is like Doc and MMs wife. She has no desire to be around the heat, loud noises or lift heavy wood and can't see any reason to get covered in sawdust. You better keep her.
   One thing surprised me  watching you sawing and that was the fact you lower the loading arms all the way as soon as the log is on the mill. I was always warned/taught to leave the arms partially raised in case a log rolled back. I always do that at least with the first couple of faces.
   Of course there are big differences since I am sawing mobile and use the arms to hold flitches to be edged and you have other support equipment to do that.
   Do you ever have a log kick back and roll backwards on the first cut or two?
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #10 on: August 01, 2022, 10:16:12 AM »
"I'm not arguing. I'm explaining why I'm right, using a loud voice." - (old saying). :D
Knowing the optimum blade speed by the sound it makes reminds me of the old assembly line maintenance guys. They could walk through a factory and just listen for machines that were "out of tune" or rhythm, and know exactly what to adjust.
PBS did a piece on one of the production sawmills near me, the workers had developed their own language using only hand signals. They could communicate and relay messages across the factory, never having to yell over the noise. One of their signals (I think it was for the number eight) could start a fight if you didn't know what it meant. :D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #11 on: August 01, 2022, 10:18:48 AM »
PatD and Kelly offloading while redbeard saws and I watch.  ;D
Offline boonesyard
  • I've got a little sawdust in my pocket
« Reply #12 on: August 01, 2022, 10:45:13 AM »
My wife Gen and I saw together all the time, couldn't or wouldn't do it without her. She does the off bearing, stickering and most of the stacking. One of the hardest workers I know. We've got a great rhythm that works well. Like anything else, not perfect all the time, but mostly. Pretty easy to not argue when everything goes smooth  :).
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Offline wisconsitom
  • Deep in the larch
« Reply #13 on: August 01, 2022, 10:50:18 AM »
@Resonator, indeed, the mill you speak of, where workers developed their own sign language, is the MTE-Menominee Tribal Enterprises mill just east of your area, in Neopit, on the reservation.
I'm a life-long learner.  That's why I made sure to start out real dumb!
Offline moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #14 on: August 01, 2022, 11:25:21 AM »
My bride helping with the sawing! :D :D :D
Now to be honest, she does help. If I need to buy something for the mill she is more than willing to help me spend the $$.
She also washes my sawdust riddled clothing.
Not in anyway complaining about the help she does give me but thought of her helping with the labor makes me laugh out loud!!
mh
"And the days that I keep my gratitude
Higher than my expectations
Well, I have really good days".    Ray Wylie Hubbard
Offline mudfarmer
  • Mama Tried
« Reply #15 on: August 01, 2022, 11:38:15 AM »
At the circle mill the sawyer and I naturally developed pretty good sign language skills while running the head saw and the edger. It is a very rapid and understandable way to communicate quickly rather than shout back and forth a million times. Figured that others developed similar schemes but never looked into it.
Trying to think of some of the signs:
thick
thin
tapered
trapezoid
edger pile (with variations for nuance)
lumber pile (with variations for nuance)
slab pile (with variations)
"shorts" pile
dust conveyor not running
dust conveyor not starting
shut down - non emergency
shut down - oh $%!^
flip cant/flitch back on the carriage
chainsaw
Wow that's nice
This log is junk
log deck start/stop/reverse
Somethin Ain't Right But I Don't Know What
BREAK TIME
etc etc
« Reply #16 on: August 01, 2022, 01:11:40 PM »
Yeah, Martha is a keeper, she can run any piece of equipment we have, some better than I can, work most two guys into the ground, and do it year after year for decades.  Sometimes she will give me "hand signals" when I'm about to make a bad cut or miss a drop, but she isn't a fan of operating the LT-70 at all, with the joysticks, she says it's laid out "wrong" (I agree to some extent).  On the other hand, she won't even hardly let me touch the SLR, that's hers, and if we ever get divorced, she will keep the forklift for herself.  She won't hesitate to run the SLR or edger for a whole day, and do it again the next.  Her dad was a long time woodworker, and Martha can run a nail gun with the best of them.  We both team up on the planing, and she stocks all the shelves with thousands of pounds of wood a week.  As she says, the showroom and building is "hers" and the "sawmill" is mine.  Don't forget, we used to build houses so she can build cabinets and lay tile with the best of them.
As you noticed, I always drop the loader arms to the ground, I've had too many logs roll off the mill deck over the years, especially doing reverse roll sawing, and used to keep the mill arms up to catch them, but never again.  I almost flipped the mill when a monster rolled off and was "caught"  by the raised lower arms, and another bent the poop out of my loader arms.  So instead, I use the crossties which are taller than the fully dropped loader arms, and angled down back to the mill.  So when log rolls off, and it occasionally does, it simply flops on top of the crossties, and I raise the loader arms again and throw it back on.  The mill never even shakes or can be damaged in any way.  The crossties take the impact of the log rolling off, not the mill.  I had one roll off the other day while I was filming and made mention that it took "maybe 15 seconds to get back to sawing" vs calling WM and ordering and replacing the loader arms.  Been there done that.
YellowHammerisms:
Offline Larry
« Reply #17 on: August 01, 2022, 02:09:44 PM »
Another great video! :)  My mill is usually set up the same way with the roller tables.  Even on the rare occasion when I'm away from home I'll take my short tables.  I really like the idea of help being in the safe zone as you describe it.
I did notice one thing.  The cant hook laying on the ground so Martha had to bend over and pick it up for every log.  That gets old for me.  Somebody said "Take steps to save steps". :D :D
« Reply #18 on: August 01, 2022, 02:52:05 PM »
You and me both.  I saw her do that, time after time, and to my credit, I didn't say a word, even though it was driving me crazy.  A classic violation of the "Steps" rule!
However, I used my best "husband" judgment, and didn't say anything, or I would have surely gotten some "sign language" and thought in order to keep the video title accurate, it was best left unsaid.
YellowHammerisms:
Online KenMac
  • I'm not as new as I was. but often feel very old!
    • ItGrowsOnTreesWoodworks.com
« Reply #19 on: August 01, 2022, 09:45:06 PM »
My wife knows I have a mill and knows where it's located, but hardly ever puts eyes on it and I'm better off that way for sure. Her task is the banking end and paying sales taxes. You're a lucky man, Robert.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Nominating my wife for wife of the year
Started by sawman on General Board
Last post November 28, 2019, 07:15:51 PM
by sawman
My wife
Started by Kevin on General Board
Last post March 04, 2022, 05:31:12 PM
by Hilltop366
Wife has gone mad
Started by Ken on General Board
Last post November 05, 2015, 11:57:52 AM
by sawguy21
If only my wife would allow me.
Started by Ernie on Chainsaws
Last post March 06, 2022, 11:18:31 PM
by JJ
